my cluster fuse keeps going out...help
Old Oct 25, 2006 | 08:30 AM
ek9tl's Avatar
Default my cluster fuse keeps going out...help
hey guys, everytime i put a fuse in the cluster is keeps going out no matter what size it is. What shudd i do begin fixing this problem. Thanx for all help.
Old Oct 25, 2006 | 08:34 AM
instructor74's Avatar
Default Re: my cluster fuse keeps going out...help (ek9tl)
what year and model? Do you have rear marker lights? Do you have an after market radio? If the answer to the last 2 ? is yes then check the dimmer line on the wiring harness going to the radio to be grounding out that will blow that fuse
Old Oct 25, 2006 | 08:37 AM
ek9tl's Avatar
Default Re: my cluster fuse keeps going out...help (instructor74)
yea i tink it has sumting to do with the radio b\c when it was installed then it started to happen. Now what shudd i do with the dimmer wire from the radiio?
Old Oct 25, 2006 | 08:45 AM
If you used an after market harness adapter to wire the radio harness to. Find the line on the harness marked dimmer (refer to the package that it came in also it should tell you what color the wire is) I would bet that it is not used by your radio and is just loose. Any of the wires that you do not have hooked up you should have a crimp cap on them to keep them from grounding out. Don't use electrical tape it only comes off AND NEVER USE A LARGER FUSE THEN WHAT A LOCATION CALLS FOR. That is why they are fused to keep bad things from happening to your car if there is a short in the wiring
Old Oct 25, 2006 | 08:47 AM
ek9tl's Avatar
ok thanx alot for ur help man..i wil try this soon. Thanx...
Monstarrr*
Apr 13, 2012 04:55 PM
Leo C
Audio / Security / Video
Jan 20, 2007 06:01 PM
Leo C
Jan 13, 2007 02:18 PM
turbotime
May 29, 2005 08:27 PM
kleanlscivic
Mar 16, 2004 06:57 PM
