WTS: B18A1
Want to sell a B18A1 from a 1990 Acura LS. It had 144k miles on it, and ran excellently. The donor vehicle was scrapped due to rust. This was originally going to be swapped in a CRX, but the owner screwed me on this, leaving me with the engine and out 300 bucks.
It is in pieces, parts labeled and bagged. Ready for hone/bore job and valve job.
It is complete with factory ECU, fuse boxes, transmission, instrument cluster, original clutch cable, radiator with fan, fuel harness, axles (to be traded in for core charges), and other odds and ends. Ready to be sent for overhauling. The starter is still installed, and I have the alternator, which needs to be replaced, but can be used for core charge, also. I can supply pictures so you can see exactly what I have.
$300
I am located in Ohio. You pick up, otherwise shipping is going to be somewhere between 150 and 200 bucks, I'd have to find out.
Email for more info and/or pics.
Nate
$300
Nate
