Innter tie rod / Rack end bushing problem?
Old Oct 24, 2006 | 06:08 PM
Magick211's Avatar
Default Inner tie rod / Rack end bushing problem?
Here is the deal. my passanger side inner tie rod has a lot of up and down play im thinking its the rack end bushing. is this most likely the problem? The car drives really straight but you can hear the tie rod clunking at higher speed 40-65
Modified by Magick211 at 9:38 PM 10/24/2006
Old Oct 24, 2006 | 06:26 PM
Tyson's Avatar
Default Re: Innter tie rod / Rack end bushing problem? (Magick211)
im glad you read this thread already.
https://honda-tech.com/zerothread?id=1117870
the inner tie rod itself should be able to ROTATE up and down. however without play. but i dont think thats what you mean. you mean the part of the rack on the passenger side is able to move up and down, right? so if thats the case, then yes it cant be anything but a bad rack end bushing.
you need to replace it. and dont forget to retighten the pinion gearbox before youre done.
are your boots ripped too? it accelerates the wear. its just plastic.
Old Oct 24, 2006 | 06:35 PM
Magick211's Avatar
Default Re: Innter tie rod / Rack end bushing problem? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
Yes it moves up and down really easy, also the boot is torn and the car has 280k on it
Old Oct 24, 2006 | 06:38 PM
Tyson's Avatar
so then its a no brainer.
all my advice and tips are in that thread. please read it carefully.
good luck. id love to hear your feedback once its done.
Old Oct 24, 2006 | 06:55 PM
Magick211's Avatar
just wanted to make sure thanks alot man
Old Oct 30, 2006 | 08:18 AM
Magick211's Avatar
Anyone ever used the energy suspension rack end bushing?
Old Oct 30, 2006 | 08:24 AM
Tyson's Avatar
thats not the right bushing.
Old Oct 30, 2006 | 09:35 AM
Magick211's Avatar
Oh ok thanks for clearing that up i was about to go to the parts store to get it guess ill go to the dealership and get the correct one.
Mr. Em1
21
Jun 7, 2010 03:24 PM
heeltoehonda
Suspension & Brakes
Nov 12, 2009 11:42 AM
RanCRX
17
Feb 10, 2009 02:59 PM
yOnKiNaToR
May 17, 2005 11:46 AM
Hcivic88
Aug 28, 2002 02:35 PM
