Going from a dohc zc to a d16z6, having problems???
Old Oct 24, 2006 | 02:45 PM
Red_Si's Avatar
Default Going from a dohc zc to a d16z6, having problems???
Hey, I had a dohc zc in my hatch and it blew up, lol. I am currently putting a d16z6 into my car running obd1, i can't get it running properly and have a couple questions about wiring and things, so here we go:
1. There is a Black/Red wire that comes from the passenger side shock tower plug, where does this go?
2. There is also a Brown/Black wire that comes from the passenger side shock tower plug, where does this go?
3. There are two white wires that come off of the si dizzy plug, one goes to the passenger side shock tower plug and the other goes to the driver side shock tower plug, which side goes to which pin on the dizzy plug???
4. There is a Blue/Yellow wire that comes off of the si dizzy plug, where does this go for regular mpfi (si) wiring?
5. There is a Blue/Green wire that comes off of the si dizzy plug, where does this go for regular mpfi (si) wiring?
6. There is a brown connector off of the thermostat housing, which plug goes here and from which part of the wiring harness?
7. There is a white connector off of the drivers side of the intake manifold, which plug goes here and from which part of the wiring harness?
8. There is a plug off of the drivers side of the back of the intake manifold, it is bolted to the back of the intake manifold and has a plug that hangs on about 6" of wire, which plug goes here and from which part of the wiring harness???
Please help me, i got the car started after having timing issues, and now it's running like ***, i believe if i get these wires and plugs where they need to be it will run perfect. Please help me, TIA
-Steve
Old Oct 24, 2006 | 04:41 PM
Red_Si's Avatar
Default Re: Going from a dohc zc to a d16z6, having problems??? (Red_Si)
ok i found out that number 1 and 2 from above are grounds and that's how i have them currently.
I really need to find out where the Blue/Yellow and Blue/Green wires originally come from before they get to the distributor, they are currently wired for a zc and i need them to be wired for an si.
Old Oct 24, 2006 | 05:03 PM
Red_Si's Avatar
if anybody is not understanding what i need, i need instructions on how to take zc wiring and turn it into si wiring, basically. I had a zc and i swapped the si dizzy plugs on and now i need to know which wires go where. i really need to know where the blue/yellow and blue/green wires went originally in an si?
Old Oct 24, 2006 | 05:15 PM
Red_Si's Avatar
I also need instructions on how to change the ecu wiring side from zc to si???
PLEASE HELP ME!!! i NEED THIS RUNNING BY TOMORROW!!!
Old Oct 25, 2006 | 03:14 AM
Red_Si's Avatar
can anybody help me??? i thought this was supposed to be a tech site??? please help!!!
Old Oct 25, 2006 | 10:12 AM
lightcrx's Avatar
what does your dizzy plug look like right now round or square?
Old Oct 25, 2006 | 02:22 PM
Red_Si's Avatar
Default Re: (lightcrx)
well i'm running obd1 but it is round (si) and then i have the rywire harness
btw i figured out what you were talking about with the rubber boot thingy, i'm working on that now.
ninty1civic
Nov 11, 2009 11:33 PM
C_R_X_V_T_E_C
12
Mar 20, 2007 01:06 PM
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
Red_Si
Oct 25, 2006 03:44 AM
