Secondaries never open, can I just take the butterfly plate out???
Old May 5, 2002 | 04:35 PM
redman223's Avatar
Default Secondaries never open, can I just take the butterfly plate out???
I have tried, time and time again, to find out what the hell is wrong with my stupid car, and it turns out that it is the intake manifold. I did the vaccum tests and the secondaries never open, I even checked the solenoid and its working fine, so its gotta be the ECU problem. ESPECIALLY SINCE THERE IS NOTHING IN PIN A17 OR A20!!!!!!!
So, now I am pissed off, because I even tried sticking a wire into that those pins (tried them both) and tapping into the pink/blue wire on the IAB solenoid. Both to no avail. Now I am completely lost.
Can I just take the stupid manifold off and tear out those dumb butterfly plates??? How much would high end improve and low end suffer???
Old May 5, 2002 | 04:52 PM
threatcon13's Avatar
New User
Default Re: Secondaries never open, can I just take the butterfly plate out??? (redman223)
replace it with a skunk2 manifold.
Old May 5, 2002 | 05:09 PM
jamal-188's Avatar
Default Re: Secondaries never open, can I just take the butterfly plate out??? (ALLMOTORDC2)
yeah, don't do that, you'll loose too much low end. I'd try to fix it or buy anther IM!!
Old May 5, 2002 | 06:51 PM
redman223's Avatar
Default Re: Secondaries never open, can I just take the butterfly plate out??? (jamal-188)
What else will I need to make the manifold work? Do I need a new throttle cable and bracket? Or is that only for new TB's?
I'm trying to find the best price that I can on the SKUNK2 IM, but keep seeing the usual 310 shipped. I'll just cruise Ebay I guess.
So what all will I need?
1. Manifold
2. Hondata gasket (not totally needed, but might as well put it on)
3. ???
andrewxxcarlson
Nov 24, 2011 08:51 AM
Mike95lude
K Series
Jan 16, 2010 12:27 PM
bettsbanger
Dec 11, 2008 10:19 AM
EGstreetcar
Sep 4, 2002 03:10 AM
Sideshow9090
May 24, 2002 04:32 AM
