how do you install valve stems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 »</TD></TR><TR><TD CLASS="quote">how do you install valve stems onto rota slipstreams?</TD></TR></TABLE> normally the slipstreams dont come with valve stems, but the tire shop will use the rubber snap-in ones. they probly charge u 2~7 buck each stem.
try tightening the nut on the stem and see if it is loose????? or the grommet might not be in all the way and pinched and letting air out that way
