h22 swap linkage?
hey im doing a h22 swap in my 94 del sol. i payed 1500 for the swap and it came with everything except the shift linkage. i was wondering were would be the best place to find it at or if anyone had any for sale.
for all the h22 swaps i've done, i've found everything i've needed from either wrecking yards or the local pick and pull. all parts should be readily available, and can be had for much cheaper than honda will quote you. pm me if you need a list of everything that you'll need. good luck on your swap. https://honda-tech.com/zerothread/650329 there should be alot of helpful info in the link i posted above. any questions you may have, this thread should be able to answer them for you. if not, those who participate should have info for you. good luck on your swap.
