first time changing prelude pads... question..
Old May 5, 2002 | 03:15 PM
NONKonformyst's Avatar
Default first time changing prelude pads... question..
I have the factory service manual, but is there anything that I need to worry about from anybody's experiences with doing this? Thanks a lot.
Old May 5, 2002 | 03:18 PM
Accord94DX's Avatar
Default Re: first time changing prelude pads... question.. (95redLUDE)
make sure to siphon some of your brake fluid out of the resevoir, you do not want that spilling all over the place. Apply anti-squeek over the shims. Um...pressing the piston is easy with a pair of big channel locks.
Old May 5, 2002 | 06:13 PM
Prelude Vtec 23's Avatar
It's real easy, you should have no problems at all.
Old May 5, 2002 | 06:46 PM
Gennady's Avatar
New User
Default Re: first time changing prelude pads... question.. (Accord94DX)
Dont push the piston too far in, and dont touch the brake pedal while the caliper is off.
Old May 6, 2002 | 03:59 AM
dcb0821's Avatar
Default Re: first time changing prelude pads... question.. (Wont be beat)
dont press the piston in with channel locks, the piston needs to rotate as it goes in, if you can rotate it the piston will go right on in, i used a c-clamp that has a swivle head on it so that as it is applying force inward the piston can rotate.
Old May 6, 2002 | 04:26 AM
kevie88's Avatar
Default Re: first time changing prelude pads... question.. (slowlude)
Only the rears need to be rotated clockwise to retract the pistons, The front ones can be pushed in normally!
Old May 6, 2002 | 03:58 PM
PrecisionH23a's Avatar
Default Re: first time changing prelude pads... question.. (kevie88)
ditto
Old May 7, 2002 | 06:38 AM
dcb0821's Avatar
Learn something new everyday, thanks!
Old May 7, 2002 | 07:44 AM
Gennady's Avatar
New User
A cool trick is putting the old pad on the piston and pressing the pad, not the piston down with the C-clamp. This distributes force equally. Plus, its a little quicker I think.
Old May 7, 2002 | 10:14 AM
Chiovnidca's Avatar
Channel locks.
C-clamp.
hondadadcrv
Honda CR-V & Element
Jul 10, 2010 03:05 PM
kidcool1977
Nov 30, 2008 05:42 AM
hondatuner20
11
Apr 14, 2006 02:03 PM
SKDRCR
Jan 18, 2004 05:18 PM
