painting valve cover
What kind of paint should I use on a valve cover? Ive got some caliper paint laying around, and on the can it says its safe to use on engine blocks, so id assume I can also use that on a valve cover, but I just want to be sure. Its rated to 900 F.
theres a link for valve cover painting...here are some
https://honda-tech.com/zerothread?id=640755
https://honda-tech.com/zerothread?id=782937
https://honda-tech.com/zerothread?id=491789
look over these...they can help you
now i just looked on another thread and someone said to use hondabond when replacing the valve cover? is this kinda like a sealer? and do i absolutely need to use it or can i just pop the gasket back in place and bolt it right back on? i dont want to have to deal with any leaks down the road.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by attentionwhore »</TD></TR><TR><TD CLASS="quote">try doing a search. that little button works wonders
qft
</TD></TR></TABLE>qft
turbotime
Nov 7, 2005 07:31 PM
