ABS light.
Old Oct 23, 2006 | 09:39 PM
TDogg99's Avatar
Default ABS light.
i have a 97 accord and the ABS break light came on. the car feels fine though, what do you think the problem is?
Old Oct 23, 2006 | 10:05 PM
AJ06's Avatar
I have that too... always had it tho... :D
and I forgot to reset my check engine light after I got the new engne... oo well... stuuupid sensors
Old Oct 23, 2006 | 10:48 PM
gosu08's Avatar
Default Re: ABS light. (TDogg99)
happens to my car when i go above 90. dont know why. went to shop and they couldnt find the problem. said maybe the brake lever bounces. i dont know. no charge though.
Old Oct 24, 2006 | 05:51 AM
HONDAVTIS's Avatar
perhaps u should go to dealer to check whether there is problem with ABS pump, or maybe u have not changed the abs oil for a very very long time,( i think normally it should be replaced every 40000km.)
if it always comes on n never off, u should concern above problems, but if u restart ur engine, everything is fine, then should be some kind of short circuit. i dun think its a big deal, it happened on my car once.
Old Oct 26, 2006 | 07:17 PM
TDogg99's Avatar
Default Re: ABS light. (HONDAVTIS)
thanks b.
Old Oct 27, 2006 | 07:25 AM
honda_kid42's Avatar
there is an easy way to check it for free...there is a little blue plug under your glove box, pull that out and jump it with a paper clip or anything you can find, turn the car to the on position and you ABS light will blink...get the code and there are a couple threads where they list all ABS codes...
another thing is to check your fluid...i know if it is a little low it will set off your light...
irideslammed5021
Feb 25, 2010 06:05 AM
sixtodc2
Oct 4, 2007 04:15 AM
94~GSR
Sep 30, 2005 10:33 PM
nickgsi
Mar 20, 2004 02:10 AM
oioioi
Oct 11, 2002 02:47 PM
