Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow Adjustables and NYC roads question...
Old Oct 23, 2006 | 09:15 PM
Manolo's Avatar
Default Koni Yellow Adjustables and NYC roads question...
i live in NYC and everyone knows that the roads are ****. i have my konis adjusted to stiff 24/7. should i not have them adjusted like that? does the life span decrease having them like that all the time? or should i soften them up when im doing my daily things?
Old Oct 24, 2006 | 09:37 AM
CRX Lee's Avatar
Default Re: Koni Yellow Adjustables and NYC roads question... (Manolo)
I would highly suggest that you soften them up quite a bit as there is no reason for them to be cranked so high on the street. You are only just pounding yourself and your car needlessly and probably not helpiong the shocks any either.
Konis are valved to already be good performance shocks when new at the full soft setting to give the performance ride and handling balance that the engineers decided was best for the car. if you have some stiffer than stock perforamcne lowering springs, normally about 1/2 to 1 turn is plenty of adjustment to work with the higher rates (my Koni Sports are at 3/4 turn off soft for a rather aggressively sprung Ground Control-like coil-over threaded sleeve system). the shocks are normally twice as firm at the max setting as they are at the min setting so that you have a wide adjustment range for tuning and wear compensation of the what should be a 100k-150k mile lifespan of the shocks.
If you are on rough NYC roads with the shocks set at double what the Koni engineers felt that car should have, you are doing no one any favors. Even if you like your car pretty aggressive, turn them back down to about 1 turn from full soft and you will probably find that the car is actually much better in many ways.
Old Oct 25, 2006 | 12:09 PM
E-Money's Avatar
i ride with koni/eibach pro with some all season tires and i manage to get the rear off the ground all the time... its on softest setting too
dukers
Suspension & Brakes
May 5, 2005 07:20 AM
PhiLG
May 11, 2004 04:22 PM
LSintegra619
Apr 9, 2003 01:37 PM
khoa
May 15, 2002 07:49 AM
kod311
Aug 23, 2001 11:10 AM
