wider tires in front ?
Old Oct 23, 2006 | 07:20 PM
killaj12's Avatar
Default wider tires in front ?
whats up guys
right now, im running 205 50 15s all around ..
but i have to replace my rear tires asap
i found a good deal on 195 50 15s
but i was wondering if it would be a bad idea to run skinnier tires in the rear
would it affect handling ?
thanks for any help
Old Oct 23, 2006 | 07:22 PM
Eran's Avatar
HT White Ops
why don't you just switch the 205's to the rear?
Or better yet .... why not buy the right tires?
Old Oct 23, 2006 | 07:23 PM
killaj12's Avatar
Default Re: (Eran)
i guess i could put the 205s in the rear
would that be better than having them up front ?
Old Oct 23, 2006 | 07:24 PM
Eran's Avatar
HT White Ops
Default Re: (killaj12)
most definitely.
Old Oct 23, 2006 | 07:27 PM
divisionskate's Avatar
if you have the money, get 205s, if not just get the 195s. i had some bridgestone potenzas 195/65/14s up front with shatty 175/65/14s in the rear for about 2 months and never had a problem. but now i have falken zeix 205/60/14s on all fours .
Old Oct 23, 2006 | 07:41 PM
EG2Driver's Avatar
Default Re: (divisionskate)
the pontiac GXP uses wider front wheels/tires. Its fine to use i guess.
Old Oct 23, 2006 | 07:53 PM
kai-chun's Avatar
Default Re: (DeadEnd9009)
narrower tires in the rear can supposedly make the handling more neutral. By that I mean less understeer. Because rear is less grippy.
Old Oct 23, 2006 | 08:33 PM
.Grimace's Avatar
footwork mastery
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">why don't you just switch the 205's to the rear?
Or better yet .... why not buy the right tires?</TD></TR></TABLE>
why would you want to put the bigger tires in the rear on a fwd car? better traction and like he said ^^^ in theory more neutral feel
Old Oct 24, 2006 | 05:37 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: (Gremice)
well, if you are daily driving, having the same size all around will be more beneficial. you can rotora the tires for better/even wear.
if you are doing this primarily for racing or max handling, having larger tires in the front is necessary. for most fwd platforms, 64~67% of the weigh bias is on the front, thus needing larger tires.
i run 225/45-15 on 15x9 in the front, and 205/50-15 on a 15x7 in the rear. this setup has been proven extremely potent.
JDM-LuxurySport
Dec 5, 2010 08:32 AM
LSeeper
Jun 12, 2004 01:31 PM
bearboy80
Oct 20, 2003 01:55 PM
EE9
Aug 15, 2002 09:35 AM
