CRX obd1 o2 sesnor?
okay my CRX is a JDM d15b OBD-1 do i need a stock o2 sensor or do i need to get a obd1? and if so wat car would i ahve to get it for etc, cause im going to pep boys to get it.
it depends on the ECU you are using, if you are using a P28 you will need an OBD1 4 wire, if you are using the D15B ECU you will need a one wire
vw eater
Feb 4, 2007 09:47 PM
