Big Tube 4-1 makes more power across the board vs small tube 4-2-1
Old Oct 23, 2006 | 04:08 PM
SMSP's Avatar
Default Big Tube 4-1 makes more power across the board vs small tube 4-2-1
Not a Honda but All Motor related.
I finished up a 4-1 header for a guy's 1.8L DOHC Mazda Protege. He was running an aftermarket (supposedly the best piece available) Genie 4-2-1. I thought I may have gone too big on the tube size but was pleasantly surprised this weekend.
I'll be building a modded/new IM for him also to test along with a 4-2-1 header.
Modified by SMSP at 10:08 AM 11/13/2006
Old Oct 23, 2006 | 04:10 PM
lohatch's Avatar
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (SMSP)
great job dave
Old Oct 23, 2006 | 04:27 PM
All around nice guy's Avatar
* B A N N E D *
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (lohatch)
That looks like an ITR header but backwards. But don't 4-1 headers always make more power?
Old Oct 23, 2006 | 04:45 PM
SMSP's Avatar
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (Wize *** Mcgee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wize *** Mcgee &raquo;</TD></TR><TR><TD CLASS="quote">That looks like an ITR header but backwards. But don't 4-1 headers always make more power? </TD></TR></TABLE>
No, a well designed 4-2-1 can beat a 4-1 in the rpm ranges we are talking about, but I've seen 4-1s make more when the tune was terrible on the 4-2-1, which isn't the case in this test.
Old Oct 23, 2006 | 05:19 PM
type B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
No, a well designed 4-2-1 can beat a 4-1 in the rpm ranges we are talking about, but I've seen 4-1s make more when the tune was terrible on the 4-2-1, which isn't the case in this test. </TD></TR></TABLE>
i guess your 4-2-1 sucks since it loses to your 4-1
*runs away and hides*
Old Oct 23, 2006 | 05:25 PM
SMSP's Avatar
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (type B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">
*runs away and hides*</TD></TR></TABLE>
Re: B series. My 4-2-1 lost to my 4-1 only 1 time. Probably because that tuner was inexperienced.
Old Oct 23, 2006 | 05:35 PM
Whitfield Inc.'s Avatar
nice to see another header test - thats not honda only. I like the gain in the midrange ----- dave do you do private lable or too busy with retail.
Old Oct 23, 2006 | 05:39 PM
SMSP's Avatar
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (Whitfield Inc.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whitfield Inc. &raquo;</TD></TR><TR><TD CLASS="quote">nice to see another header test - thats not honda only. I like the gain in the midrange ----- dave do you do private lable or too busy with retail.
Yeh, I've gotten into some limited privite label stuff.
Old Oct 23, 2006 | 06:59 PM
Padawan's Avatar
Darth ModerVader
Is there any specific reason that you chose to utilise a 4-1 configuration on this particular setup?
Old Oct 23, 2006 | 08:13 PM
GSRCRXsi's Avatar
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (Padawan)
maybe space reasons? i know dave likes to do 4 tubes all lined up next to each other.
loving my 4-2-1 great work dave.
Old Oct 23, 2006 | 08:24 PM
Combustion Contraption's Avatar
Myth Busters.
Old Oct 24, 2006 | 03:30 AM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Is there any specific reason that you chose to utilise a 4-1 configuration on this particular setup? </TD></TR></TABLE>
This was the first prototype and 4-1s are easier/cheaper to build.
Old Oct 24, 2006 | 08:04 AM
ABCVTEC's Avatar
so in general 4-1s are only better than 4-2-1s when the 4-2-1 is tuned horribly...? Or is this with SMSP ones.
Old Oct 24, 2006 | 08:06 AM
type B16's Avatar
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (ABCVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">so in general 4-1s are only better than 4-2-1s when the 4-2-1 is tuned horribly...? Or is this with SMSP ones.</TD></TR></TABLE>
thats what smsp told me. 4-1&gt;4-2-1 when NOT tuned
Old Oct 24, 2006 | 09:06 AM
xDicktonesx's Avatar
hey sms guy,
check out VWVORTEX.com go to the 12V VR6 as well as the 24V VR6 and the R32 forum. there is not a SINGLE header available for any of those motors that makes power.
race-shop (joe) last time i checked was pushing low 12s which is hauling *** for a 12V vr6 in a mk3 and is using a stock manifold becuase there is nothing better than that available.
you said "genie" and they make a header for the VR6, but it makes less power than the stock manfold. its also about 500 bucks used. itd look like like a 6 primary tubed k24 header.
Old Oct 24, 2006 | 09:45 AM
( o )( o )'s Avatar
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (xDEFTONESx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">hey sms guy,
you said "genie" and they make a header for the VR6, but it makes less power than the stock manfold. its also about 500 bucks used. itd look like like a 6 primary tubed k24 header.</TD></TR></TABLE>
ka-ching! sounds like an untapped market....
Old Oct 24, 2006 | 09:57 AM
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (( o )( o ))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) &raquo;</TD></TR><TR><TD CLASS="quote">ka-ching! sounds like an untapped market....</TD></TR></TABLE>
thats an understatement. those poor guys, including myself, have never ever ever had a decent intake manifold or exhuast manifold. got some great cams with schrick but thats about it. the VR6 is gods motor, but everything bolted to it SUCKS.
http://forums.vwvortex.com/zeroforum?id=29
hit em up SMS guy. talk to billyvr6 and race shop joe on there as well as anthony dowd. the 12V vr6 is still an untapped platform, even for its age.
Old Oct 24, 2006 | 10:35 AM
* B A N N E D *
This was the first prototype and 4-1s are easier/cheaper to build.</TD></TR></TABLE>
I have to disagree with that .Take a look at these to headers and tell me that.
They probably cost more because you buy your collectors.It would be alot cheaper if you made them yourself.Plus there is only one U bend per tube on your 4-2-1.
Old Oct 24, 2006 | 11:45 AM
SMSP's Avatar
They probably cost more because you buy your collectors.It would be alot cheaper if you made them yourself.Plus there is only one U bend per tube on your 4-2-1.</TD></TR></TABLE>
They cost more because there are 3 collectors and you only use one collector on your header pictured above.
Old Oct 24, 2006 | 01:02 PM
lohatch's Avatar
They cost more because there are 3 collectors and you only use one collector on your header pictured above.</TD></TR></TABLE>
lol. :looksrealhard: randy is that you?? :looksrealhard:
Old Oct 24, 2006 | 01:03 PM
type B16's Avatar
oh **** is that really randy? =P
Old Oct 24, 2006 | 02:04 PM
Default Re: (type B16)
header manufacturers with one account for stirring **** and one account for diplomatic business posting.
&lt;scratches chin&gt;
interesting.
Old Oct 24, 2006 | 02:06 PM
Default Re: (xDEFTONESx)
Wize *** Mcgee
(100%)
Offline
Access Level Normal User
Permission Level Restricted Trial User
Full Name Arvy Futtbucker
Email Address wizeassmcgee@verizon.net
wow...thats who i want to build and sell me a custom header.. hahahaha
Old Oct 24, 2006 | 02:10 PM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">lol. :looksrealhard: randy is that you?? :looksrealhard:</TD></TR></TABLE>
Isn't that annoying?
Old Oct 24, 2006 | 02:14 PM
Default Re: Big Tube 4-1 makes more power across the board vs small tube 4-2-1 (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that annoying?</TD></TR></TABLE>
very. because if it was me, id be back to 10 posts a day courtesy of GEEEEKAAAAYYYY
