Lightened crank ??
Old Oct 23, 2006 | 03:15 PM
BABY NSX's Avatar
Default Lightened crank ??
I’ve done some searching on this but came up with very little good information…
What is common practice when it comes to lightening a Honda crank (namely the TypeR crank)?
As I understand a full out knife edge can reduce reliability; however I also read that removing 4-5lbs can be done without concern (assuming everything is done right).
What are people’s thoughts/experiences with this?
Thanks,
Doug
Old Oct 23, 2006 | 04:08 PM
lohatch's Avatar
Default Re: Lightened crank ?? (BABY NSX)
i did one for my last engine. put 4100 miles on it this last season with no problems. weighed 34.195 lbs stock and 29.4 lbs when i was done.
obviously magnaflux it and check for straightness before you spend your time doing all this.
balanced, tapped, cleaned and plugged oil holes, heat-treated and micro-polished.
this is a 89mm crankshaft.
Old Oct 23, 2006 | 09:51 PM
95dcsleeper's Avatar
Default Re: Lightened crank ?? (lohatch)
does it rev higher or faster??
Old Oct 24, 2006 | 07:04 AM
lohatch's Avatar
Default Re: Lightened crank ?? (95dcsleeper)
yah it revved pretty freely.
Old Oct 24, 2006 | 07:16 AM
alterdcreations's Avatar
where did you send the crank out to?
what was their cost?
Old Oct 24, 2006 | 07:41 AM
lohatch's Avatar
Default Re: Lightened crank ?? (alterdcreations)
i did the lightening myself. a local machine shop balanced it for me for $75, and i had it heat-treated at another local place for $50.
Old Oct 24, 2006 | 07:52 AM
i know castello/kms and a few others also offer this service
the heat treatment is a must right?
Old Oct 24, 2006 | 07:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">i did one for my last engine. put 4100 miles on it this last season with no problems. weighed 34.195 lbs stock and 29.4 lbs when i was done.
looks like you do great machine work
Old Oct 24, 2006 | 01:32 PM
dfoxengr's Avatar
you just used a regular lathe right?
Old Oct 24, 2006 | 01:45 PM
lohatch's Avatar
Default Re: Lightened crank ?? (dfoxengr)
yep
Old Oct 24, 2006 | 06:56 PM
i wish i had access to a lathe and alot of other tools and machine equipment.
either way i am wondering do you have to heat treat the crank after you lighten it.
i thought that you compermise the harding process only when when you weld?
Old Oct 25, 2006 | 04:29 AM
dfoxengr's Avatar
well you are not heating it above its eutectic temperature when you turn it, so the only other reason i could see for heat treating would be to relieve stress. other than that, it might be a good idea to peen the fillets on the crank, as well as where you machined.
95dcsleeper
Sep 5, 2005 06:48 PM
KillaB18
Dec 6, 2003 04:15 PM
Art701
Jun 24, 2003 06:22 AM
Louie
Sep 11, 2002 06:02 AM
Nick M
Feb 5, 2002 07:54 PM
