D16A6 Distributor Question
Old Oct 23, 2006 | 02:44 PM
89D15CRXDX's Avatar
Default D16A6 Distributor Question
I screwed up and didn't buy the Si harness while doing my swap. I have everything in order except for the resistor box wiring and my distributor wiring. I don't have any of the plugs for it and I need to install my wiring. Which wires do I connect to which wires? Can anyone PLEASE PLEASE help me out?
Thanks
Old Oct 23, 2006 | 02:49 PM
89 civic si's Avatar
Default Re: D16A6 Distributor Question (89D15CRXDX)
you have to use your stock wiring harness? and convert it to mpfi you cannot use an si wiring harness on a dx research research i have an si distributor and manifold pm for an offer
Old Oct 23, 2006 | 02:53 PM
89D15CRXDX's Avatar
Default Re: D16A6 Distributor Question (89 civic si)
No dude. I have all of the items needed to do it. I put a D16A6 head and intake manifold on my block. I am wiring my DX harness for the Si distributor and injectors. My problem is is that I didn't buy the Si harness and use the plugs off of it for my distributor or my resistor box. I need to hard wire my distributor and my resistor box to my DX harness without the plugs. Or I need to use my plugs from my old distributor and hard wire my resistor box. Believe me, I've done plenty of research, I just didn't buy the plugs and need to get creative here. I'm asking which wires I need to put to which wires on my DX harness and DX distributor plugs. The wires are different colors than what is on the Si distributor plug. Maybe if someone can find a wiring diagram for that particular part of the harness.
Old Oct 23, 2006 | 03:28 PM
rywire.com has a pinout chart for the dizzy conversion i would just solder the wires and tape them up until i got the plugs
RACEPAK
Aug 28, 2009 11:29 AM
saccord
Jul 31, 2006 11:03 AM
cjwarren4dcivic
Mar 20, 2006 02:09 PM
TEAM HATCH-N-IT 90
Jan 27, 2005 06:07 PM
EGHatchy
Jul 17, 2002 06:33 PM
