Lots of misc. Parts! B-series, Integra, etc.
Old Oct 23, 2006 | 01:38 PM
Tuan's Avatar
Default Lots of misc. Parts! B-series, Integra, etc.
<U>Motors / heads</U>
- D16y7 long block. 99 DX motor, Brand-new head, needs a new head gasket.
- D16y7 complete head
- B16a1 JDM 1st gen, complete bottom end, no knock sensor, unassembled, bare.
- B18a2, bottom end, one cyl. has 2 scratched walls about an inch long.
- B18a1 long block, siezed motor.
- 88 to 93 Acura Integra LS cable tranny, grinds into 1st,
- B20 head
<U>AFTERMARKET / ECU</U>
- Acura Intega 94 and up Gauge cluster, 12X,XXX miles on the odometer.
- 91-93 Acura integra - Ground Controls springs, green, - not coilovers
- P2E OBD2a 1996 and up Honda Civic DX ecu
- P2P OBD2a 1996 and up Honda Civic EX ecu
- P2P Automatic ECU Honda Civic EX OBD2 2000
- Autometer Phantom Air fuel ratio gauge, white face, black ring,
- Autometer Phantom Fuel pressure gauge, white face, black ring - no sending unit-- Autometer Phantom Coolant temperature gauge.
- Autometer dual gauge pod black for 92-95 Honda Civic
- LS shift ****, - really dirty
- 16" Rota GT3 center caps, polished.
<U> ACURA INTEGRA, B-series parts</U>
- 94 and up Integra, Rear cargo cover
- 94 and up Integra, Rear trunk carpet
- 94 and up, rear t-bracket mount and chasis mount
- B-series hybro fork lever
- 99 GSR swirlies, 2 only, all scratched up. – great for track.
- 94 and up GSR, P72 power steering pump. x 4
- 94 Integra LS power steering rack, lines, pump,line coolers, bottle, needs one tie rod
- 94 Integra, cruise control modules, computer, lines, cables, even button
- 1994 and up Integra Hood latch & lines
- 94 and up, Integra stock springs
- 94 and up, Integra stock side skirts – stock red
- 94 and up, GSR intake ARM w/ filter
- 94 and up, LS crank Pulley, non-obd (V-Belt) & obd1
- 04 and up, B16a / GSR crank pulley
- 94 and up, Integra Cruise control module & pedal cable & module.
- B-series Top tranny mount
- PR3 intake manifold w/ fuel rail
- PR3 crank pulley, w/ V-belt ring
- OBD1 LS intake manifold
B18A/B, Acura Integra LS cam caps
B-series oil pan, LS & B16a
B-series plug wire cover – needs repaint
B-series alternator mount x 3
B-series crankshaft pulley, LS
B-series tensioner, x 4
B-series power steering mounts. P72 & P54
B-series pilot bearing, Cable, new in box
<U> HONDA CIVIC, D- series parts</U>
- 96 EX rotors, just needs resurface.
- 96 and up Radiator, dual core, for AUTO or manual. $40
- 96 and up DX Distributor
- 96 and up Alternator
92-95 Honda Civic Cruise control module - with cables x 3
D-series, various shiftlinkages
D-series 92-95 driver side mount
D-series 92-95 top tranny mount
D-series 92-95 front tranny mount
D-series 92-2000 rear tranny mount
D-series Alternator OBD1 & OBD2 x 8
D-series Crank pulley pin & bolt
D-series alternator mounts
D-series Fuel rail
D-series throttle bodies, all missing TPS's
D-series valve cover, NON-VTEC
<U>MISC – bolts and etc.</U>
Any bolt on a Honda or Acura, tranny bolts, mounts, 10mm,12, 14, 17, 19
Fuel Pressure Regulator x 10, B,D, all kinds
T3 turbo exhaust housing – 5 bolt flange - NO 4 bolt
T4 turbo polish housing x 2, don't know the sizes.
2000 Honda Accord V6 Starter, brand new in box!
H22 VTEC cams w/ cam stock cam gears x 2
H22 VTEC Prelude motor starter
60" piping for header back for an integra or civic
S13 Nissan ECU for KA20DE motor, $20
"Y" manual switch exhaust pipe, cast iron, & lever
Motorized scooter, suspension
I have a box of misc. crap from small brackets, oil cooler/breather, sensors, and etc.
<U>TOOLS & Material</U>
- Transmission jack. red, Used once to do change a tranny swap on a Nissan 240. Bought it for $199. Asking $80. I have no place to store it.
IF YOU TOOK THE TIME TO READ THIS ENTIRE POST, PLEASE BUMP!!!
Modified by Tuan at 9:41 AM 10/3/2007
Modified by Tuan at 2:00 PM 6/10/2008
Old Oct 23, 2006 | 01:55 PM
johnnay's Avatar
i want the tranny mount. call me at 714 724 7811 i'll pick it up today
Old Oct 23, 2006 | 01:58 PM
ef0cmacro's Avatar
Default Re: Lots of misc. Parts! B-series, Integra, etc. (Tuan)
bump! might have to take those AC lines from u in the future. but for the present bump
Old Oct 23, 2006 | 08:28 PM
Tuan's Avatar
Default Re: Lots of misc. Parts! B-series, Integra, etc. (efocmacro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efocmacro &raquo;</TD></TR><TR><TD CLASS="quote">bump! might have to take those AC lines from u in the future. but for the present bump</TD></TR></TABLE>
let me know!
Old Oct 23, 2006 | 09:53 PM
TmeX05's Avatar
bump .. althought i didn't read everthing
Old Oct 24, 2006 | 07:55 PM
miss chauzilla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuan &raquo;</TD></TR><TR><TD CLASS="quote">- RAZO - RED, Carbon fiber shift ****. $10
pics? i'm very interested.
Old Nov 7, 2006 | 07:05 AM
Tuan's Avatar
bump diddy
Old Nov 7, 2006 | 04:55 PM
z6EJ1's Avatar
wood da ground control springs fit in an eg?
Old Nov 8, 2006 | 01:39 PM
Tuan's Avatar
Default Re: Lots of misc. Parts! B-series, Integra, etc. (z6EJ1)
I have no idea to be honest.
Old Nov 9, 2006 | 12:22 PM
Tuan's Avatar
I need to get rid of this stuff! I don't even have a HONDA anymore! CHEAP!!!!
Old Nov 13, 2006 | 09:47 AM
Tuan's Avatar
bumpity.... just too dam lazy.
Old Nov 15, 2006 | 12:03 PM
Tuan's Avatar
Trade for misc. turbo parts.... =0
Old Nov 25, 2006 | 11:14 PM
Tuan's Avatar
updated!
Old Nov 26, 2006 | 12:32 AM
JerkzBebot's Avatar
Bump fo lots of parts
Old Nov 27, 2006 | 08:28 AM
Tuan's Avatar
Default Re: Lots of misc. Parts! B-series, Integra, etc. (JerkzBebot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerkzBebot &raquo;</TD></TR><TR><TD CLASS="quote">Bump fo lots of parts</TD></TR></TABLE> Thanks for the bump!!!
I need to get rid of this stuff before it goes into the trash.
updated the list:
-Rev-hard turbo log-manifold
-Down-pipe
-HKS wastegate wth 9 lb spring & 12 lb spring (need to check)
Old Dec 1, 2006 | 10:43 AM
Tuan's Avatar
bumpoty
Old Dec 4, 2006 | 12:13 PM
97itypeR's Avatar
bump pm sent
Old Dec 4, 2006 | 01:29 PM
IntegraDriver's Avatar
Default Re: (97itypeR)
Old Dec 4, 2006 | 10:17 PM
Tuan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itypeR &raquo;</TD></TR><TR><TD CLASS="quote">bump pm sent</TD></TR></TABLE>
replied!
Give me offers! The more you pick up, the better the deal!
Old Dec 6, 2006 | 12:18 PM
Tuan's Avatar
Default Re: (Tuan)
bumpity
Old Dec 7, 2006 | 12:00 AM
Pr0ject93hb's Avatar
Default Re: (johnnay)
dont need anything but i'll bump yah
Old Dec 7, 2006 | 01:15 AM
JDM RHD eg6's Avatar
Default Re: (Pr0ject93hb)
Pm u Tuan
Old Dec 7, 2006 | 09:50 AM
Tuan's Avatar
Default Re: (JDM RHD eg6)
Thanks Kev!
Old Dec 7, 2006 | 04:01 PM
accountant's Avatar
bump...
Old Dec 7, 2006 | 04:21 PM
LFA Squad::the Godfather's Avatar
Default Re: Lots of misc. Parts! B-series, Integra, etc. (accountant)
pmd
