need help victor X manifold
Old Oct 23, 2006 | 01:09 PM
Roid's Avatar
Default need help victor X manifold
i have RC 330cc injectors and tried to install the into the victor x manifold and they will not fit in with the o-rings on them. it looks like the manifold needs to be machined out a little for them to fit so i figured that i would try to see if my stock injector/fuel rail setup would work for the time being. the injectors fit fine in the manifold but the fuel rail will not bolt up. it has a 1/4 inch space between the manifold and the fuel rail any input would be helpfull my first build.
Old Oct 24, 2006 | 08:18 PM
Roid's Avatar
Default Re: need help victor X manifold (Roid)
anyone who has installed this manifold and could give me some advise would help alot
Old Oct 25, 2006 | 12:35 PM
jllong95's Avatar
is it the stock fuel rail???
Old Oct 25, 2006 | 06:31 PM
Bailhatch's Avatar
Default Re: (jllong95)
I just made aluminum spacers on the one i did. make sure to allow enough 'squish' to seal the bottom of the injector. I think I ended up using 9.5mm on a B18
Old Oct 26, 2006 | 11:50 AM
Bakeoff's Avatar
the stock intake manifold used black ro brown spacers. You can remove those from teh stock manifold and reuse them. If they end up being too thick, you can shave them down.
Old Oct 26, 2006 | 06:17 PM
Roid's Avatar
Default Re: (Bakeoff)
thanks for the feedback i ended up making spacers for the stock fuel rail/injector setup works perfect, will post more when complete
jon570
Mar 7, 2019 07:01 AM
maximusmda
Jan 24, 2010 12:05 PM
iukaman
Oct 11, 2004 10:58 AM
turbonitrousgsr
Jan 24, 2004 07:01 PM
