Turning rotors w/o replacing pads?
Just wondering how "bad" it is. I have moderate vibration on braking, and the rotors could use a turning. However, there is still a lot of life left in the pads. However, I don't want to have unevenly worn pads on newly turned rotors if it prematruely wear the rotors or cause the car to pull one way or another when braking, etc.
Thoughts...
Thoughts...
I've done this. But I laid down some sand paper to sand the brake pads a bit. I had no problems. You just want to make sure the pads are flush on the rotor surface.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">Yeah. Just Take some 100 grit sand paper and flatten the pads and you'll be fine</TD></TR></TABLE>
x2
As long as the pads are worth keeping on there while you are in there...
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 »</TD></TR><TR><TD CLASS="quote">x2
As long as the pads are worth keeping on there while you are in there...</TD></TR></TABLE>
Yeah, I just peeked from the side and it looked like there was plenty of material left. I'll have to pull one side and check it out to make sure though.
Thanks for the replies guys! Did you do anything to make sure that what you had sanded was level? lol, I'll probably sand them and get something slanted/un-level
I might just do this to get rid of the shake, then pick up new rotors/pads next summer
AnAccordIsForever
Mar 28, 2007 10:33 AM
Mikes2000civicsi
10
Jan 14, 2007 04:35 AM
JDM_SOHC
25
Nov 15, 2006 06:49 AM
H2290
10
Jul 28, 2006 01:56 PM
