going from HF to SI...oh the questions i have
Old Oct 23, 2006 | 09:58 AM
rice a roni's Avatar
Default going from HF to SI...oh the questions i have
since the vacuum line routing in the hf looks like this
http://i75.photobucket.com/alb...g.jpg
http://i75.photobucket.com/alb...2.jpg
and the vaccum line routing it he si looks like this
http://www.we-todd-did-racing....D.jpg
how would i go about this conversion? would i need the fast idle on the back of the si intake manifold?
Old Oct 23, 2006 | 10:13 AM
2slow4stock's Avatar
no you don't.
Old Oct 23, 2006 | 10:57 AM
downest's Avatar
Default Re: (2slow4stock)
I just did this, put an A6 into a stock HF, with the Si knuckles and brakes. Everything drops in, you just need to rewire the fast idle solenoid thing on the back of the manifold. One wire (I think it's black/yellow or something) is the +12V and splices into the one on the one next to it, and the other you have to run to B2 on the PM6, which is the same as the wire for the shift light on the HF.
Old Oct 23, 2006 | 11:10 AM
Default Re: (downest)
basically i dont care about the shift light thingy. and the egr is out, not putting that in again and what? draw me something on paint for the fast idle thing.
Old Oct 23, 2006 | 11:47 AM
downest's Avatar
Default Re: (rice a roni)
Found it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Next is the fast idle control solenoid valve (F-I-C-S-V), which is mounted on the back of the Si intake plenum, near the EACV. it's plug uses 2 wires: black/yellow and a blue. Black/Yellow (later referred to as B/Y) is a 12V + and routes to the B/Y from the EACV plug. The Blue wire goes to pin B2 on the ECU. B2 is currently connected to the green/yellow wire from the "shift up light" in the guage cluster. The plug for this wire contains a green/orange and a yel/red wire. It is under the driver's side of the dash, connected alongside the fusebox with a white plug. Cut the green/yellow wire from the plug on the harness and splice in the blue wire from the Fast idle control solenoid valve, with the new wire going toward the ECU. Don't connect the F-I-C-S-V wire to the plug under the dash, or weird stuff will happen with your shift light! The "shift up" light is now disconnected (YAAAAAA!!!) and the green/yellow wire on the plug under the dash now hangs bare. F-I-C-S-V wiring is now complete. </TD></TR></TABLE>
Old Oct 23, 2006 | 12:27 PM
ok that makes more sense...the only thing left to do is get a ficv.
Old Oct 23, 2006 | 12:31 PM
downest's Avatar
Should be one on the Si manifold...
99teggsr
Sep 21, 2013 07:04 AM
detuned
Jun 26, 2008 01:58 PM
newbiecrx
Feb 26, 2006 02:01 PM
JohnnieChimpo
Apr 24, 2004 08:27 AM
pdiddyparsons
Nov 14, 2002 10:44 AM
