DART tall deck question
This may be a stupid question but I was just curious. I bought a tall deck dart block and I was wondering if I was going to be needing a particular header now d/t the added 14mm in height of the block. thanks for any help!
I bought it as a complete shortblock. I have a part number for a timing belt. i need the exhaust,intake manifold,head gasket. thats pretty much it, at least all I can think of right now.I have skunk2 stage 3 cams,84mm pistons,eagle stroker crank. what kinda hp u think I should be pushin with that???
nothing is done to the head yet but I plan on pnp valve job. I am just tryin to guess what kind of quarter mile time I can getwith the setup. I just NEED to find some headers
I'm in the same boat as you there, major master, but I haven't seen any conclusive evidence that you need a custom header. I'd try contacting Larry @ Endyn to see what kind of headers he runs on his dart blocks.
alright. if u find out will ya let me know please. I want thiscaryp and running by feb. cuz i need 3 months for bullsh** paperwork to get the car re-registered and re-vined
B18 headers will NOT fit, custom is the way to go. I have a Dart talldeck myself and have been through this myself. Plenty of good choices out there, I went with Hytech.
My setup is 85x92mm btw, power is in my sig.
1300!!!! wow!!! well I guess I got myself into some big money for this project. DAMN!!! I should be pushin over 200 hp with my setup. the head willbe getting worked on before I finish with everything
Here's a thread with info on my setup : https://honda-tech.com/zerothread?id=1426425
That should work, if the header has a joint like the OEM ITR header on the front of the block, adding a 1/2" spacer here would give the necessary oil pan clearance.
