94 civic ex auto manual wiring questions
yes i have searched but this is my situation
i have 94 civic ex auto chasis and i am swapping in a b18b with a 00 si tranny but i was wondering on the wiring can i keep the cruise control working and if so how do i do it and what else do i need to get please any additional info or help will be appreciated thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostd ls »</TD></TR><TR><TD CLASS="quote">yes i have searched but this is my situation
i have 94 civic ex auto chasis and i am swapping in a b18b with a 00 si tranny but i was wondering on the wiring can i keep the cruise control working and if so how do i do it and what else do i need to get please any additional info or help will be appreciated thanks</TD></TR></TABLE>
Well I know you CAN keep the cruise control, but no, I don't know how to do it / what you have, etc. (Easier to look at the car and tell what needs to be done
As far as parts, you have the LS ECU?, the P28 won't work unless it's chipped with a B18B basemap. Don't need to run an oil tap b/c ur not going LS/V - Hrm...as long as you get the right mounts it should be pretty straight forward. You can use the EX harness (might run into changing a few plugs, nothing major), use the LS mounts (I don't know what you have ot use for the tranny mount though), LS ECU, you're going to need the axles (obviously)..Blah
This is too hard.
Why don't you tell us exactly what you have instead of tryin to play guessin games b/c this **** aint workin :-\
Got the tranny, got to get, or have the ECU, B axles, B mounts, obviously all the sensors and ****, alternator, etc., IM, EM, TB (all that **** that goes on an engine, not much is swappable between B and D series motors), and I'd use the EX harness..
Which parts do you have exactly?
).As far as parts, you have the LS ECU?, the P28 won't work unless it's chipped with a B18B basemap. Don't need to run an oil tap b/c ur not going LS/V - Hrm...as long as you get the right mounts it should be pretty straight forward. You can use the EX harness (might run into changing a few plugs, nothing major), use the LS mounts (I don't know what you have ot use for the tranny mount though), LS ECU, you're going to need the axles (obviously)..Blah
This is too hard.
i have a whole integra that i am using for parts but it is automatic so the motor already has a harness and i already ordered the transmission mount from hasport i have a ls computer and i bought a 00 civic si tranny and i got the clutch pedals brake and gas clutch master cylinder lines and new slave cylinder that is all i have collected so far i know i need some more but i am going to go ahead and get the wiring over with but i still want my cruise control to work if possible any help please
RED95EG6
Sep 21, 2009 08:34 AM
visciousHONDA
Jun 18, 2008 04:29 PM
AccordVT
Apr 10, 2008 08:25 PM
