HONDA/ACURA/350Z PARTS *worth reading*
contact:Warren
email: streetprojectz@aol.com
pictures: yes just ask
i will flex on some parts prices
-7” microvision monitor w/ remote and mount (NIB) $100
-Nissan 350Z 30 LED front parking lights 15 Amber 15 White can be wired to do different functions 05 and older NEW $125
-95 Acura Integra GSR OBD 1 alternator working condition $45
-OBD2 CFK sensor and timing belt gear $50
-Pontiac manifold vacuum gauge old school good condition. TELL YOUR DAD $60
-30/30 prop valve $20
-Integra sunroof motor $5
-Integra arm rest bracket $2
-Civic steering column knuckle $2
-Integra hood pull $2
- civic Battery hold down $2
-acura integra Slave cylinder $5
-Integra steering knuckle $2
-Integra power window motor $5
-Civic fuel pump $5
-Radiator stay x2 1 powder coated $5
-Summit ground strap $5
-Greddy 60mm universal gauge pod $25
-GM 3 bar map sensor no pigital $60
-99 GSR VTEC selinoid $80
-VSS B16 was cracked and glued back $30
-IACV 99 GSR $20
-3040 prop valve w/ DA mount $35
-Lot of powder coated civic brackets 3 included $25
-Civic 92-95 VTEC selinoid $25
-Stock 92-95 HB Civic side skirts $30
-5 igniters for HID lights mercedes audi $25 each
-1 ballast Mercedes / Audi $40 each
-STR yellow cigarette lighter $10
-MC guards M12x1.5 21156 $25
-96-98 P2P-A32 ECU OBD2A $40
-Kenwood 2 channel AMD 200 watts $40
-GSR brake swap f&r new pads new rotors. No ebrake cables. Cross drilled slotted CLEAN swap $400
-99 GSR cam gears stock $20
-99 GSR carpet real clean 8.5 out of 10 $100
-93 Toyota Camry lowering springs sprint 2” drop $40
-99 GSR leather wrapper steering wheel w/ Acura air bag $100
-TYC 92-95 Civic spoon style mirrors painted fresh red $50
-Integra 94-97 Wings West front lip. Scuffed and scratched $40
-Starter D series $25
-Bare LS intake manifold $20
-Taped GSR oil pan $40
-Front only mud flaps 92-95 Civic cut on drivers side flap $10
-Oil pump NEW B series $100
-Integra kick panels black $20
-5 speed pedal set Acura $20
-Acura Integra rear lower control arms $40
-D series throttle body $20
-2x clutches $20
-Flywheel GSR $30
-2x Acura Integra cargo cover $40 each
-2x 80% left Duloup SP Sport Fm900 *1 looks like it was flat spotted* $60
-92-95 rear hatch glass $40
-92-95 Civic rear hatch $30
Modified by StreetProjectz at 9:42 PM 10/24/2006
Modified by StreetProjectz at 9:58 PM 10/24/2006
Modified by StreetProjectz at 5:01 PM 10/27/2006
Modified by StreetProjectz at 12:07 AM 10/29/2006
Modified by StreetProjectz at 12:08 AM 10/29/2006
Modified by StreetProjectz at 12:03 PM 10/29/2006
Modified by StreetProjectz at 1:28 PM 10/29/2006
Modified by StreetProjectz at 5:59 PM 10/29/2006
Modified by StreetProjectz at 2:54 PM 11/1/2006
Modified by StreetProjectz at 4:40 PM 11/6/2006
Modified by StreetProjectz at 7:06 AM 11/8/2006
Modified by StreetProjectz at 3:14 PM 11/10/2006
Modified by StreetProjectz at 1:36 PM 11/11/2006
-Civic fuel pump $5
-IACV 99 GSR $20
-2x clutches $20
-Flywheel GSR $30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetProjectz »</TD></TR><TR><TD CLASS="quote">
--5” auto meter tach w/ shift light Black face $40
you got picture?
you got picture?
corey.recai
Northeast (Sales)
Apr 21, 2015 04:22 PM
