Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor??
Old Oct 23, 2006 | 02:02 AM
Xemu's Avatar
Default Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor??
I'm in the process of wiring up my conversion harness for obdo-obd1 conversion and I have 4 wires for my O2 sensor-a brown,purple,yellow,grey wires and they are all suppose to go to the 4 wire o2 sensor.I'm waiting on an engine harness so it's not like I can go out and look??
I have a black wire which I know goes to the Vtec solenoid,green that goes to the vtec pressure switch,white goes to the knock sensor (i'm not even sure if I have one of those either????
Any help?? Thanks
Old Oct 23, 2006 | 04:45 AM
Autoworks's Avatar
Default Re: Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor?? (Xemu)
The Si has a 1 wire O2 originally
Old Oct 23, 2006 | 05:07 AM
crawfo661's Avatar
Default Re: Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor?? (Autoworks)
nope, a single wire, z6, y8,y7, and i think d15 b have 4 wire o2 sensors, put it this way if it origionally came obd1 it has a 4 wire
Old Oct 23, 2006 | 08:27 AM
Rywire's Avatar
Default Re: Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor?? (crawfo661)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawfo661 &raquo;</TD></TR><TR><TD CLASS="quote">nope, a single wire, z6, y8,y7, and i think d15 b have 4 wire o2 sensors, put it this way if it origionally came obd1 it has a 4 wire</TD></TR></TABLE>
MOST usdm cars from 92+ have 4 wire o2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu &raquo;</TD></TR><TR><TD CLASS="quote"> I'm in the process of wiring up my conversion harness for obdo-obd1 conversion and I have 4 wires for my O2 sensor-a brown,purple,yellow,grey wires and they are all suppose to go to the 4 wire o2 sensor.I'm waiting on an engine harness so it's not like I can go out and look??
Any help?? Thanks</TD></TR></TABLE>
What is the engine setup... more info if you want answers
Old Oct 23, 2006 | 08:57 AM
89 civic si's Avatar
Default Re: Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor?? (droppedcrxsi)
the d15b vtec has a 1 wire as does the vtec-e engine...
Old Oct 23, 2006 | 09:12 AM
SIred91's Avatar
Rainman
Default Re: Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor?? (89 civic si)
crx si has 1 wire 02.
Old Oct 23, 2006 | 10:03 AM
Xemu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">the d15b vtec has a 1 wire as does the vtec-e engine...</TD></TR></TABLE>
Doing a mini-me swap D15B2 bottom and Z6 head and trying to figure out how I'd wire the O2 sensor??? So if I have a D15 bottom and one wire O2 sensor do I not need the 4 wires to the sensor or splice them all?????
Old Oct 23, 2006 | 10:12 AM
JUN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu &raquo;</TD></TR><TR><TD CLASS="quote"> Doing a mini-me swap D15B2 bottom and Z6 head and trying to figure out how I'd wire the O2 sensor??? So if I have a D15 bottom and one wire O2 sensor do I not need the 4 wires to the sensor or splice them all????? </TD></TR></TABLE>
depends which ecu are you using..... If you use a p08 ecu then you only need a 1 wire o2 sensor. if you use a p28 then 4 wire sensor.................
Old Oct 23, 2006 | 11:10 AM
Xemu's Avatar
Default Re: Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor?? (JUN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. &raquo;</TD></TR><TR><TD CLASS="quote">
depends which ecu are you using..... If you use a p08 ecu then you only need a 1 wire o2 sensor. if you use a p28 then 4 wire sensor.................</TD></TR></TABLE>
It's a chipped P28 isn't there a cheap way out of this like a Mustang O2 sensor rather than the $120 Honda O2???
Old Oct 23, 2006 | 11:17 AM
SiMateoAko's Avatar
uh, you're smoking crack.
vtec-e requires a five wire o2 sensor.
d15b vtec should have a four wire o2 sensor.
Old Oct 23, 2006 | 11:28 AM
Xemu's Avatar
It's a chipped P28 isn't there a cheap way out of this like a Mustang O2 sensor rather than the $120 Honda O2???</TD></TR></TABLE>
Anybody??
Old Oct 23, 2006 | 11:34 AM
Jonknee's Avatar
i just bought a denso 4 wire o2 from ebay for 38 bux for the d15bvtec.
Modified by La-Quiete at 12:52 PM 10/23/2006
Old Oct 23, 2006 | 11:49 AM
JUN.'s Avatar
Default Re: Trying to wire up my conversion harness,does the CRX SI have a 4 wire O2 sensor?? (SiMateoAko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiMateoAko &raquo;</TD></TR><TR><TD CLASS="quote">uh, you're smoking crack.
d15b vtec should have a four wire o2 sensor.</TD></TR></TABLE>
a stock p08 ecu from a car that has a d15b vtec engine has just a 1 wire o2 sensor.............................
Old Oct 23, 2006 | 12:01 PM
Rywire's Avatar
This thread has to much misinfo in it... If you have a chipped p28, just burn a chip with the o2 heater removed... then you can use a 1 wire o2, and the problem is solved
nharper12
Feb 22, 2014 10:22 AM
crapanese
Nov 8, 2006 09:57 AM
redflaredb1690
May 12, 2006 01:56 AM
red_crx
Feb 4, 2005 08:15 PM
4DRPIMPIN
Sep 5, 2003 08:56 AM
