Best Clutch??? 4 98 integra daily driver/street
Old Oct 23, 2006 | 12:03 AM
Kangolbrand's Avatar
Default Best Clutch??? 4 98 integra daily driver/street
I have a 98 integra just try to do a couple launch since I just go the car, I did it at 35k and hesitated as if I drop the clutch which I didnt, I pause longer than a regular peel out when launching at 35k. So this leads to believeing the clutch is gone. Since the car is at high RPMs and when I let the clutch out it doesnt catch for crap meaning its just spinning instead of grabing.
So what brand type of clutch should I get. Some clutch kits dont come with flywheel should I buy it or reuse mine? Which is better.... money is not really a object, I want the best.
CAR MODE:
98 gsr 4 door
MSD
Managcore wire
aem intake
skunk2 intake manifold
skunk2 cam gears
as of right now.
I want something that well grab quick but not to quick becuase I use this as a daily driver. But I would like to run it some nights if its possible.
any info would be helpful, Thanks
Old Oct 23, 2006 | 12:12 AM
DC2_005200's Avatar
Well i am always happy with Exedy Stage two clutch. Nice three puck cermic disk, nice grab, and still daily driver
Old Oct 23, 2006 | 12:32 AM
what you think about act 6 puck clutch kit its like 3 hundred something... I know its not recommend for daily driving but I've seen people have this and do daily driving all the time. How much does the exedy stage two clutch go for?
Old Oct 23, 2006 | 12:49 AM
mostly likely well get the Exedy Stage 2 clutch kit, would I need a upgrade flywheel also?
Also, how much does a shop usually charge labor to switch out your clutch? Thanks so much for the help!
Old Oct 23, 2006 | 07:54 AM
9000rpms's Avatar
I have a stage 4 sprung six puck and I daily drive it. Now that I am used to it I love it. But then again I am boosting in 6 months so I needed it to hold 450hp.
If I was not going for big power I would have gone with the sprung stage 3 carbon kevlar composite.
As Long as the clutch is sprung you can pretty much get away with anything...like I said though stage 4 is HARD to get used to daily driving.
Old Oct 23, 2006 | 08:45 AM
all-mtr-teg's Avatar
Default Re: (Kangolbrand)
check out action clutch, better quality than exedy.
Old Oct 23, 2006 | 10:31 AM
4DRDB8GSR's Avatar
Default Re: (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">check out action clutch, better quality than exedy.</TD></TR></TABLE>
Agreed I,m Using A Action 2MS 6 Puck Sprung Clutch, Action 12lb Flywheel, And Dual Diaphram P.P. It Is Fine For A Daily Driver Maybe A Little Overkill For 165WHP However I Will Be Boosting This DB In About 6 Months.
Here Is Their Link, And A Picture Of My Clutch Kit And Flywheel
https://honda-tech.com/zero...ge=15
Old Oct 23, 2006 | 11:08 AM
Kentagious's Avatar
Default Re: (4DRDB8GSR)
exedy is ok...I run a ACT Street disk. Its like a 6 puck, but it is also made for a daily driver. It will hold up to 350hp. You will not be disapointed! You'll also need a new flywheel, or you can have yours resurfaced. I'd recomend a lightend one. I also have the ACT 12lb flywheel...http://www.advancedclutch.com/ check it out
Old Oct 23, 2006 | 11:27 AM
str8JDMteggy's Avatar
Dont go right through act's website its a rip off. Look around and you can find the clutches for a lot less.
Old Oct 23, 2006 | 11:42 AM
Chriz's Avatar
Default Re: (str8JDMteggy)
exedy stage 2
Old Oct 23, 2006 | 12:01 PM
WalkerGSR1's Avatar
Xtd stage3, 6 puck and 8 pound flywheel= around 250 shipped
Old Oct 23, 2006 | 12:43 PM
Leo C's Avatar
Night Owl
Default Re: (WalkerGSR1)
You DON'T need an exedy stage 2 with those mods. A stage 1 holds up to 200 whp no problems. And take out your MSB box, it is hurting your bolt-on GSR's performance.
Old Oct 23, 2006 | 01:17 PM
thanks for the replies guys, how much would a shop usually charge to change out my clutch? So what type of ACT clutch should I get? I know my cars not fast reason for me wanting a good clutch to help with the launches. Thanks
Old Oct 23, 2006 | 01:20 PM
Leo C's Avatar
Night Owl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies guys, how much would a shop usually charge to change out my clutch? So what type of ACT clutch should I get? I know my cars not fast reason for me wanting a good clutch to help with the launches. Thanks </TD></TR></TABLE>
You'll be looking at around $400-500 without the cost of the clutch. You need a <U>STAGE 1 clutch</U>, a stage 2/3 is absolutely not necessary with those mods.
Old Oct 23, 2006 | 02:56 PM
4DRDB8GSR's Avatar
ACT= Market Crap
Action Clutch=Completely Seperate Company
You'll Pay About $250 At A Good Shop To Get A Clutch And Flywheel Installed.
Old Oct 23, 2006 | 07:30 PM
vladd's Avatar
Default Re: Best Clutch??? 4 98 integra daily driver/street (Kangolbrand)
get a exedy stage 1. several friends had it and liked it.
Old Oct 23, 2006 | 07:39 PM
Leo C's Avatar
Night Owl
Default Re: Best Clutch??? 4 98 integra daily driver/street (civicdxtyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">get a exedy stage 1. several friends had it and liked it.</TD></TR></TABLE>
Old Oct 23, 2006 | 08:43 PM
EXEDY STAGE 1 CLUTCH + EXEDY FLYWHEEL
http://cgi.ebay.com/ebaymotors...wItem
EXEDY STAGE 2 CLUTCH + FIDANZA FLYWHEEL
Which should I buy? are they even reasonable price? Thanks
Old Oct 23, 2006 | 08:47 PM
Leo C's Avatar
Night Owl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">EXEDY STAGE 1 CLUTCH + EXEDY FLYWHEEL
Which should I buy? are they even reasonable price? Thanks</TD></TR></TABLE>
Just get your stock flywheel resurfaced. I only looked at the stage 1 clutch since that's the one you should be getting. That's a bad deal anyway, you can get just the Exedy Stage One clutch kit for abobut $240 shipped on ebay.
Old Oct 23, 2006 | 09:12 PM
Turbo3gAccord's Avatar
Default Re: Best Clutch??? 4 98 integra daily driver/street (Leofski)
exedy stage 2
Old Oct 23, 2006 | 09:59 PM
lol, state 1 or 2??? im leaning towards 2 just trying be on top of things... hate to change my mind ones its in and what not. is there a big differences between state 1 and 2?
Old Oct 23, 2006 | 10:46 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">lol, state 1 or 2??? im leaning towards 2 just trying be on top of things... hate to change my mind ones its in and what not. is there a big differences between state 1 and 2?</TD></TR></TABLE>
you have no need for stage 2 with a basically stock engine. it is much harsher than the stage 1. the stage 2 is a 3 puck, and it skips pretty bad at light throttle. you have to mash the gas and drop the clutch pretty quick for a smooth start; driving in traffic sucks with it. it's also a lot stiffer than the stage 1. unless you're heavily modifying the engine sometime soon, i'd recommend a stage 1. it's cheaper and smoother. you'll get no benefits from a stage 2.
Old Oct 24, 2006 | 10:12 AM
stage 1 it is, thanks guys
Old Oct 25, 2006 | 11:02 AM
Kentagious's Avatar
I've had two GS-Rs and have used the ACT street disk every time and loved it. You can't go wrong with ACT Here is the whole clutch kit with Xtreme duty presure plate. http://www.prostreetonline.com...-xtss/
Old Oct 25, 2006 | 11:08 AM
Leo C's Avatar
Night Owl
Default Re: (Kentagious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kentagious &raquo;</TD></TR><TR><TD CLASS="quote">I've had two GS-Rs and have used the ACT street disk every time and loved it. You can't go wrong with ACT Here is the whole clutch kit with Xtreme duty presure plate. http://www.prostreetonline.com...-xtss/ </TD></TR></TABLE>
You don't need a 100% torque holding increase over stock on a bolt-on GSR. An Exedy stage one for half the price is a much better choice for the OP.
