Anyone with a full JDM Climate Control Swap
I am looking for a pinout for the connector between the Air Mix Motor and the brain. If anyone has the unit uninstalled or can see their installed unit could you please tell me the locations and colors of the wires that go from the brain to the connector? Any and all help is extremely appreciated as I am stuck with my car in pieces and unable to complete this install without this info.
Thanks
Thanks
CW ROTATION, SAE 2 BOLT MOUNTING, 3000 P.S.I., MAX R.P.M. 4000
11/16" DIAMETER KEYED SHAFT , 3/16 KEY THREADED END
SHAFT LENGHT 1" UNDER THE THREAD ( 1/2" Thread)
TWO SECTION PUMP
TWO SECTION PUMP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen23cc »</TD></TR><TR><TD CLASS="quote">CW ROTATION, SAE 2 BOLT MOUNTING, 3000 P.S.I., MAX R.P.M. 4000
TWO SECTION PUMP
What is this?
TWO SECTION PUMP
What is this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `VTEC` »</TD></TR><TR><TD CLASS="quote">there's a few threads on this matter that included pictures. try searching? i know that's a cliche` answer but i just saw it last week. look hard!
mugen23cc.. that's sad..</TD></TR></TABLE>
I have search every thread in here and it does not exist on this site. I have also been in direct contact with http://www.jrcormier.com who wrote the complete install up and put it on a website for all of us to use. He does not have the answer either. Maybe f you tried searching you would have seen my other posts in those threads about other problems I had with this install and known I already searched.
Thanks for your help
slow motion
Jul 17, 2004 07:46 AM
