hood question
i always thought that using the same thing that makes the hatch open, just unlatch it and it rises and then push it back down... probably not practical but if i were to ever make my hood do that, i'd use 4 of those haha.
haha yeah.. i didnt know if i made sense... maybe someone would have understood.
edit for others:
4 of those, at each corner of the hood to make it rise as soon as it is unlatched from inside. and then push it down to latch.
edit for others:
no what im saying is like you know how u open a hood right and u landed on the stick so it could stand slanted but i seen other cars that they open there hood like almost all the way to the back till like it looks straight. this is what i mean look at those two civic how there hoods open
[IMG][/IMG]
[IMG][/IMG]
there are a couple of stops at the back of the hood hinges. take off the hinges, remove the stops, and you can sling it all the way back. i don't have a picture, but they'll be very obvious when you're taking things apart.
if u push a crx hood up to far it hits the windshield and can crack the glass. Only the newer hondas can do the straigh up prop. IF you doing a swap and hte hood is a problem, take it off, only 4 bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">if u push a crx hood up to far it hits the windshield and can crack the glass. Only the newer hondas can do the straigh up prop. IF you doing a swap and hte hood is a problem, take it off, only 4 bolts.</TD></TR></TABLE>
yup. raise it too high and the corners will also start digging in...just pull the thing off when needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">neither of you make sense. yet, i understood what both have said. </TD></TR></TABLE>
lol
lol
exactly..... i was only familiar with EGs and EKs doing that.
