Need some good info on this..........ep3/dc5
Old Oct 22, 2006 | 09:11 PM
streetsold6teeny8's Avatar
Default Need some good info on this..........ep3/dc5
I've searched but havn't found anything really good. I need facts.
Ok if you were to put a type-s head on an ep3 si motor, what are the gains, is it worth it, is there even any gians? I need all the info. Now as far as worth it assume the motor was dirt cheap Because its a close friend whose fortunate to swap out and put in a type s. In my opinion the stock motor is slow and wak becaus eof the head and how most the the time its 3 not 4 valves that are working. Not an expert here just what I been reading. So I assume that a type-s head would make a big difference. Also since the ep is vtec it can handle high rpm once its tuned etc. If i've said anything wrong or w/e correct me. Thanks for your time...
Old Oct 23, 2006 | 03:21 AM
FullEP3's Avatar
Default Re: Need some good info on this..........ep3/dc5 (streetsold6teeny8)
Can't do it ... it's not like the old B-Series! Just go out and buy a complete Type-S swap ...
Old Oct 23, 2006 | 09:12 AM
ooo **** that sucks but thanks
Old Oct 23, 2006 | 11:06 AM
usmc39273's Avatar
Default Re: (streetsold6teeny8)
I know for a fact you CAN do it, my friend put a type S head on his 02 Ep3, I'm not sure what was all needed to do it but I do know there was not too much to it.
Old Oct 23, 2006 | 01:31 PM
jdmd's Avatar
yes, you can do it. but it's probably not really worth it unless you redo the whole bottom end. the a3 motor has a 9.8:1 cr. but if you're cracking it open you might as well rebuild the bottom end. good luck man.
Old Oct 23, 2006 | 08:08 PM
Thanks alot ppl appreciate the feedback.. How much does the head go for??? because im thinking on doing it. I mean i got the engine harness ecu and motor and tranny. all i need is the head and all the hasport stuff.
boostedteg1203
Feb 23, 2010 09:59 PM
95CivicDx51
Jul 16, 2008 08:30 PM
egkyran
13
Feb 22, 2006 04:13 PM
mustninty
12
Aug 24, 2004 05:06 PM
