gsr oem rod bearing question....
Old Oct 22, 2006 | 05:39 PM
NA JDM GSR's Avatar
Default gsr oem rod bearing question....
im lookin on like acuraoemparts.com and acuraparts247.com...u kno like the main oem parts site where they have every part and im trying to buy gsr oem rod bearings...and the sites have this below....are these the same bearings??? they should b the same cuz their all rod bearings...
13211-P72-003 BEARING A, CONN ROD 8 2000 INTEGRA 11.33 9.01 Qty:
13212-P72-003 BEARING B, CONN ROD 8 2000 INTEGRA 11.33 9.01 Qty:
13213-P72-003 BEARING C, CONN ROD 8 2000 INTEGRA 11.33 9.01 Qty:
13214-P72-003 BEARING D, CONN ROD 8 2000 INTEGRA 11.33 9.01 Qty:
13215-P72-003 BEARING E, CONN ROD 8 2000 INTEGRA 11.33 9.01 Qty:
13216-P72-003 BEARING F, CONN ROD 8 2000 INTEGRA 11.33 9.01 Qty:
13217-P72-003 BEARING G, CONN ROD
Old Oct 22, 2006 | 06:37 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: gsr oem rod bearing question.... (GSR KiNg)
They have different thicknesses. You need to see what the engine has that you are rebuilding and match. You really need to search google for "hondahookup manuals". There you will find a very valuable resource.
Old Oct 22, 2006 | 07:29 PM
NA JDM GSR's Avatar
Default Re: gsr oem rod bearing question.... (Dogginator)
how do i find out what my engine has?
Old Oct 22, 2006 | 08:03 PM
Racermech's Avatar
This was actually covered in one of you other threads. You where asking about reusing the bearings and I think I posted a link to another thread that said about figuring out the correct size.
So I would suggest searching for your own thread and looking at that.
Old Oct 22, 2006 | 09:37 PM
-Darren-'s Avatar
Default Re: gsr oem rod bearing question.... (Racermech)
http://tech.hybridgarage.com/t...l.pdf
download that to your computer and read up in the engine section about how to tell what bearings you need.
you can check this link out for some additional help also.
http://forums.evans-tuning.com...light
Old Oct 23, 2006 | 04:37 AM
IN VTEC's Avatar
The last digit in the first set of five numbers determines the color (thickness) of the bearing.
13211-P72-003
If I remember correctly, the lower the number, the thicker the bearing.
1 = BLU
2 = BLK
3 = BRN
4 = GRN
5 = YLW
6 = PNK
7 = RED
Old Oct 23, 2006 | 04:44 AM
M2S~Jaime's Avatar
What about just getting an aftermarket bearing set, like ACL or King???
igorka_91
13
Jul 5, 2009 12:29 PM
marcussmith26
Jan 17, 2006 02:45 PM
Dee
Mar 7, 2002 08:01 PM
