Bad Spark plugs and spark plug wires makes tapping noise??
Old Oct 22, 2006 | 05:38 PM
B20inDCinLBC's Avatar
Default Bad Spark plugs and spark plug wires makes tapping noise??
If your spark plugs or spark plug wires are bad, would it make a tapping noise. Something that sounds like it needs a valve adjustment?
Old Oct 22, 2006 | 07:44 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Bad Spark plugs and spark plug wires makes tapping noise?? (B20inDCinLBC)
normally faulty wires and plugs will cause a misfire and some arcing...as for the noise i would recommend a valve adjustment as you questioned in your post
Old Oct 22, 2006 | 08:06 PM
valve job was done, and still some tapping
Old Oct 22, 2006 | 08:42 PM
ejmatzell's Avatar
Default Re: (B20inDCinLBC)
not to steel from your thread... but when you did your valve adjustment, (not to sound like a ricer) did you notice a power gain? i really need to get one done...
Old Oct 22, 2006 | 08:46 PM
__oversea's Avatar
Default Re: (ejmatzell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejmatzell &raquo;</TD></TR><TR><TD CLASS="quote">not to steel from your thread... but when you did your valve adjustment, (not to sound like a ricer) did you notice a power gain? i really need to get one done...</TD></TR></TABLE>
lol.
it just make car run smooth like new. should be checked every 40-50k miles. not really sure about mileage
Old Oct 22, 2006 | 09:54 PM
no, didn't notice HP gain, just got rid of the annoying tapping sound though. I can't notice any power because right now it's untuned.
Old Oct 23, 2006 | 08:28 AM
ejmatzell's Avatar
^ gotcha, thanks
Old Oct 23, 2006 | 08:31 AM
skunked's Avatar
If you have a bad wire it will make a ticking sound as it arc's off whatever it's grounding to. Like others said, it will run very rough as well. At night it will look like Star Wars under your hood if that was the case
Aftermarket header's will also create a louder "ticking" sound from the motor which is normal.
Old Oct 23, 2006 | 05:49 PM
where would the light show come from though?
Old Oct 24, 2006 | 07:36 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20inDCinLBC &raquo;</TD></TR><TR><TD CLASS="quote">where would the light show come from though?</TD></TR></TABLE>
from wherever the wires are arching if that's the problem.
edmfactory
Jun 19, 2012 05:55 PM
Ritchie
Mar 23, 2011 02:52 AM
mynameizstitch
Jun 10, 2009 07:17 AM
dynamitezz
Oct 28, 2006 08:07 PM
accordisslow
Jan 5, 2006 07:09 PM
