2000 DX Hatch, sway bar question
Old May 5, 2002 | 09:53 AM
Greg L's Avatar
Default 2000 DX Hatch, sway bar question
I have a 2000 DX hatch, with no factory sway bars on it. I was looking through my Helms and found out that the rear lower control arms are pretty much the same as the ones on the Si and have holes for the sway bar. My question is, is there anything i need to do to get a comptech rear sway bar to fit on there? Now, on to the fornt. i was looking at the Helms again and found out that i have no holes in the lower arms to mount a front sway bar. I was wondering if i bought some EX or Si lower arms if i could just simply bolt up a Suspension Techniques sway bar. Any input would be greatley appreciated. Thanks, Greg
Old May 5, 2002 | 10:08 AM
TheIntegraGuy's Avatar
Default Re: 2000 DX Hatch, sway bar question (WannaBFast)
yes..the rear you probably wont have any problems...as for the front...dx's suck....( i have one too..so i know )...but anyhow..you have to get the front ex arms in order to get sways in the front..I also believe that neuspeed makes a lower front tie bar...so thatll also help..
Old May 5, 2002 | 10:41 AM
phatcivic99's Avatar
Default Re: 2000 DX Hatch, sway bar question (EJ_ALbeRT)
hey i hear the itr bar is better. and guess what i happen to have one for sale. i am selling it for 200 bux. and it is the whole kit, bar, bushings, endlinks, beaks kit. it is brand new and never been used or installed. just to let you know. email me at phatcivic99@yahoo.com
Old May 5, 2002 | 11:09 AM
Greg L's Avatar
Default Re: 2000 DX Hatch, sway bar question (phatcivic99)
Does the ITR rear sway werk on my car without major mods? If not i'll defintley buy it, does that $200 include shipping?
[Modified by WannaBFast, 8:13 PM 5/5/2002]
Old May 5, 2002 | 11:19 AM
GokuSSJ4's Avatar
the SI is just bolt on! but if you want to run a 23mm on the back go with the Comptech
as far as for the front i would recommend using CTR,SI sway bar 26mm .
the only thing that you will need front LCA ,forks ,endlinksand some bolts .
Old May 5, 2002 | 11:21 AM
Greg L's Avatar
Default Re: 2000 DX Hatch, sway bar question (Spoon1)
how big is the Si rear?
Old May 5, 2002 | 11:22 AM
tFUnK's Avatar
i got a front sway bar for sale... its a 22mm and it came off of my ex. complete with bushing endlinks brackets, you just need the arms i think. make an offer if interested asian_funk@yahoo.com
Old May 5, 2002 | 11:23 AM
tFUnK's Avatar
i think it's 14mm
Old May 5, 2002 | 11:44 AM
Greg L's Avatar
how big is the ITR rear sway?
Old May 5, 2002 | 11:48 AM
Jackson's Avatar
si front sway 26mm
itr rear sway 22mm with beaks srk
Old May 5, 2002 | 12:11 PM
Greg L's Avatar
I think I'm gonna go with an Si front sway, and an ITR rear sway. What stuff for the front would i need to get the Si front one to werk?
Old May 5, 2002 | 12:20 PM
Jackson's Avatar
Front sway, endlinks, LCAs, forks, d-brackets and bushings. I got mine complete for $175, so that gives you a used price.
Old May 5, 2002 | 12:39 PM
Greg L's Avatar
Default Re: 2000 DX Hatch, sway bar question (Jackson)
Did u get em throgh a buisness like import auto salvage or through another person?
Old May 5, 2002 | 02:49 PM
00-ITR-373's Avatar
Don't know if you want it or not, but I have a complete SI rear sway I'll let go for 120 shipped!
IM me if interested.
Old May 5, 2002 | 02:55 PM
sohc_boy's Avatar
Default Re: 2000 DX Hatch, sway bar question (00-ITR-373)
for a lil more u could just get a set of aftermarket swaybars. i know that suspension techniques has the front and rear kit for your car for around 250 buks and also provides more ground clearance than the factory stuff (its tucked up closer to the body).
Old May 5, 2002 | 03:11 PM
Jackson's Avatar
Default Re: 2000 DX Hatch, sway bar question (sohc_boy)
That is the first i have heard anyone say there isn't ground clearance with the factory sways, i think that is a load of bs. I would stick with OEM.
[Modified by Jackson, 4:18 PM 5/5/2002]
Old May 5, 2002 | 04:46 PM
hey greg i emailed you
Old May 5, 2002 | 04:58 PM
Greg L's Avatar
i emailed u back, are u on AIM, if so IM me at VSM EK9. Later
Old May 5, 2002 | 07:30 PM
racecarpete's Avatar
I'd also like to know where you got the Si Front bar with the lca's forks and all that for 175. That is an awesome price.
Old May 5, 2002 | 07:35 PM
tonyxcom's Avatar
Default Re: 2000 DX Hatch, sway bar question (SilverCivic2k)
I highly recommend the SI/CTR front sway setup over anything else on the market today.
I paid 300 for my setup, but it still needed the forks, but it did come with the CTR red strut bar, which I sold for 110 on ebay. Forks and bolts cost me roughly $70 brand new, so my setup was around 250.
175 is a killer price. But I am sure if you look around long enough you can find a setup at that price. the average should be around 200-250 though.
Old May 5, 2002 | 07:38 PM
CheezeFrog's Avatar
Default Re: 2000 DX Hatch, sway bar question (tonyxcom)
FWIW, if you go with the Beaks Quick-Swap EK kit (ITR sway bar & hardware + SRK), you're going to have to drill two holes in the subframe. No biggie, but it's something you'll want to be aware of.
Old May 5, 2002 | 07:40 PM
GokuSSJ4's Avatar
s/t dont compare to oem front sway ,26mm and is all bolt in !
for the rear unless that you have the kit to run the 23mm itr ,i wouldnt get it .
IMO prefer comtech.
Old May 5, 2002 | 07:42 PM
GokuSSJ4's Avatar
you could also check out tonyxcom set up he is running front si/ctr sway bar and rear itr with the kit .
tonyxcom's Avatar
Default Re: 2000 DX Hatch, sway bar question (CheezeFrog)
Also, If you get the Beaks quick swap kit, its meant for SI's, so the kit doesnt come with the SI endlinks that you need. But will can get those for you as well.
And I agree, the only safe (subframe tearout) rear kits for hatchbacks are the beaks and the comptech.
Old May 5, 2002 | 07:57 PM
xXreaperXx's Avatar
whats up randino......hows it goin
