have spoon cam gear want to know how do u install them???
Old Oct 22, 2006 | 01:57 PM
94lvstreetscene's Avatar
Default have spoon cam gear want to know how do u install them???
ok I have a set of spoon cam gears and I want to install them on my gsr block my motor is pulled and am soon to be putting it into my 91 crx with hasport mounting kit. I heard U had to pull the cams out to install the cam gears???
Old Oct 22, 2006 | 03:02 PM
4gencivicef9's Avatar
Default Re: have spoon cam gear want to know how do u install them??? (94lvstreetscene)
nah just take off your timing belt, and then there is one bolt on each cam gear holding them on, after you take them off and reinstall the new ones make sure to torque them down properly and check timing.......
make sure you set the new cam gears at 0" degress and make sure the allen keys are tight.
Old Oct 24, 2006 | 06:51 AM
did you put them on...!?
integlstrike1
Aug 13, 2006 07:45 AM
stevieteg
May 10, 2005 09:50 AM
rotorhead70
Mar 2, 2003 09:48 PM
Buckshot
Jan 14, 2003 08:03 AM
agent marlon
Nov 19, 2002 07:58 PM
