What is this little plug on the window called?
Old Oct 22, 2006 | 12:07 PM
saikou's Avatar
Default What is this little plug on the window called?
When I purchased my Lude, on both the drivers and passenger side windows, the little black plug was missing. I tried searching under "window plug/seal" and didn't find what I was looking for.
Actually, I guess its called a window plug. I guess my real question is this:
On the above picture, do I only need to purchase 21, 22, and 23? Two of each, obviously for both windows. Thanks.
Old Oct 22, 2006 | 12:40 PM
lude1888's Avatar
Default Re: What is this little plug on the window called? (saikou)
Your going to need 20,21,22, and 23. Also possibly 29 I believe is what the bolts will hold up to enabling the window to slide up and down.
Hawkze_2.3's Avatar
That plug is actually a guide for the windows to keep them in the track. I'd get all 4 of those parts for each side.
Grapevine TX- I lived in Keller for 15 yrs.
Old Oct 23, 2006 | 07:36 AM
hella_usdm's Avatar
Default Re: What is this little plug on the window called? (Hawkze_2.3)
will replacing these parts keep my windows from rattling?? Thats so effing' annoying!
Old Oct 23, 2006 | 10:13 AM
Hawkze_2.3's Avatar
Default Re: What is this little plug on the window called? (hella_usdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hella_usdm &raquo;</TD></TR><TR><TD CLASS="quote">will replacing these parts keep my windows from rattling?? Thats so effing' annoying!</TD></TR></TABLE>
Yes! It holds the window in place.
Old Oct 23, 2006 | 11:19 AM
manbearpig's Avatar
how in the world do you get them out??? I've been trying to get my window out for like 30 mins now and it wont budge.
Old Oct 25, 2006 | 04:26 AM
manbearpig's Avatar
Default Re: What is this little plug on the window called? (joinerneal)
bump for help please
Old Oct 25, 2006 | 04:28 AM
WhiteBB2's Avatar
dude, have you eevr messed with the power windows before? I can tell you how to get the window out, but I cant tell you how to get it back in and functioning right again. Mine is off track somehow...Luckily I am getting a new complete door and I dont have to worry about it.
Old Oct 25, 2006 | 07:36 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joinerneal &raquo;</TD></TR><TR><TD CLASS="quote">bump for help please </TD></TR></TABLE>
Number 7 is a rubber strip that is taped on and covers up several screws. Pull off the strip and undo the screws. Then take the door panel off and onbolt the window from the rail (2 bolts). It should slide out after that.
Old Oct 25, 2006 | 08:25 AM
manbearpig's Avatar
Default Re: What is this little plug on the window called? (WhiteBB2)
yeah man, I've dealt with them ....... why couldnt you get one back in? all you have to do is attach the window to the brace and put the bolt back into the rail... right?? reverse the process? I don't see what would cause it not to function properly...
ChillinInTheDA
Sep 15, 2010 09:54 PM
Vtec315
Oct 20, 2007 11:08 AM
lYellowDragonl
Audio / Security / Video
16
Oct 13, 2004 11:58 AM
Alpha_GSR
Apr 7, 2003 09:44 AM
