Ground clearence "Race header"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YashiMotors »</TD></TR><TR><TD CLASS="quote">Which one of the famous raceheaders has the best ground clearence?
SMSP, Rage, Hytech, DTR, Spark Racing, etc....
B-Series on EG/EF
</TD></TR></TABLE> I have not had a Sparks in the shop, but of all the others SMSP has the best ground clearence.
B-Series on EG/EF
the only 2 that are production are the rage and sparks. the others are custom.
rage is a good header but the clearance is a little lacking.
on a crx.
on a crx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 »</TD></TR><TR><TD CLASS="quote">anyone have pics of the ground clearance of rage, dtr, or smsp on a dc integra chassis ?</TD></TR></TABLE>
look at the clearance compared to the oil pan. doesnt matter what car its in. look at the oil pan and then compare that to how low your oil pan hangs.
any design similar to smsp will obviously have the best clearance. The tubes from each cylinder are parallel with each other in a row 4 wide and not double stacked like others
Notice that most of the headers with the "good clearence" are built to match the car or chassis...not to mention that they are build 1 off. Of course they will fit better then a "shelf" header that is built to work on alot of applications.
EF chassis have clearence with more then just headers when it comes to performance parts or swaps = K's hit the hood / H hits the fire wall / B turbo no ac 92up rad / headerz are not the only issue with that chassis.
my SMSP header was built for the engine, not the chassis. im sure custom header builders could make special adjustments for special needs but the main focus is building it to the engine setup.
TWINK1E
30
Sep 13, 2011 01:37 PM
