Reset the ecu in a 3rd gen
Old Oct 22, 2006 | 11:14 AM
PnoyJeff's Avatar
Default Reset the ecu in a 3rd gen
how is it done
Old Oct 22, 2006 | 11:58 AM
mugenDA9 lover's Avatar
Default Re: Reset the ecu in a 3rd gen (PnoyJeff)
unplug the battery for a while
Old Oct 22, 2006 | 01:05 PM
Dogginator's Avatar
Daisy... Daisy...
Pull the 7.5A backup fuse in the underhood fuse box for about 30 seconds. Make sure that you know your radio code if it is the stock unit.
Old Oct 22, 2006 | 02:39 PM
PnoyJeff's Avatar
Default Re: Reset the ecu in a 3rd gen (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Pull the 7.5A backup fuse in the underhood fuse box for about 30 seconds. Make sure that you know your radio code if it is the stock unit.</TD></TR></TABLE>
thats what i read when i searched...but i also heard about u have to run your engine 10min before and after u reset it so ur idle can adjust and stuff....i was wondering of that mainly..is that pretty much proper procedure?
thanks
Old Oct 22, 2006 | 02:44 PM
Dogginator's Avatar
Daisy... Daisy...
It will learn as you go for idle, etc.
Old Oct 23, 2006 | 02:10 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyJeff &raquo;</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
you should let it idle for 10 minutes after, no need to do it before. i've noticed that if i reset my ecu and don't let it sit for a little bit the idle will be really low at first.
eg6-crvtec65
Apr 4, 2007 08:31 PM
rukawa1one
Feb 18, 2005 04:31 PM
lakerschamp2000
Jul 15, 2004 05:02 PM
Ek9Max
Mar 9, 2004 06:35 AM
sleepyhamsterlx
Nov 26, 2003 06:52 PM
