HELP!! with motor swap, we are putting a zc motor
HELP!! with motor swap, we are putting a zc motor in a 92 EG right now it has a d15 in it. and i wanted to kno if the d-series wire-harness would go directly to the zc motor. if anyone has done this swap b-4 give me some input cause I'ma-gonna-need it
the zc sohc non vtec is the same as the stock motor tat was in your car so u prolly dont have it and if you do forget it
the zc vtec is the same as a z6 swap all you have to do is wire in vtec
dohc zc waste of time its a d16a1 from a 1st gen integra basically
it is dohc and I kno bout the d16 but i dont have a d16 and u cant put a b16 vtec ecu to a d16 without tearing it up so thats y we pick the zc motor. i have a b18b but im waiting on a vtec head but thats going n the DA. just kno the zc will runthe same motor beat a gsr teggy hands down and the zc had no mods at all except for the b16(vtec) ecu but the zc blew up b/c of 9 grand rev limit. stock honda valve springs (non vtec)of course can only hold 7grand at the most.
what? the dohc zc is a d-series dual cam.................................u sure u know what ur doing? cuh on ht noone else could understand you...............................
are you saying that your 1st gen teggy moyor beat s a third gen gsr?
Civic Hx-T
34
Jun 17, 2016 09:29 PM
