Swaping a B16 from a 90crxsi to an 88crxsi
Old Oct 22, 2006 | 09:14 AM
TravisB16a's Avatar
Default Swaping a B16 from a 90crxsi to an 88crxsi
I have a 90crx si with a b16a2 swap but the body is almost not worth repainring so i found a clean 88si shell. I know the front motor mount on the bottom has to be cut and a small indent on the wheel well has to be made for the alt to fit. But other than that can anyone think of what else might have to be done to drop it into an 88.
Thanks
Old Oct 22, 2006 | 03:17 PM
NikoZai's Avatar
Default Re: Swaping a B16 from a 90crxsi to an 88crxsi (TravisB16a)
see http://www.droppedcrxsi.com
From that donor car, you should have pretty much everything you need. Remember that the 1990 CRX and 1988 CRX wire harnesses are slightly different. Non-interchangeable.
dohc_vtec_acura1
Dec 14, 2007 09:52 AM
Mugen2324
Apr 10, 2006 07:34 AM
Knoppix
Jul 26, 2004 08:15 AM
