H22 Cams: Skunk PRO 2+ vs JUN
The cam will be teamed with the matching valvetrain (skunk will use skunk valvetrain/jun will use jun valvetrain) with 12.5:1 compression, pp head. I havent decided on the exact bottom end setup yet.
I'm interested to see a Skunk2 Pro2 cam also. Haven't seen anything on them. Send me some Pro2's and I can always compare them to the JUN's in my car.
spec vs spec should tell you a lot...I have yet to see anyone run the skunk pro cams in an H, only the old skunk cams....
If they are anything like the pro's are to the B series, for the h22, they should slaughter the JUN cams, as far as h22 cams go, the JUNs, though the beefiest popularly available cams, are relatively small when compared to custom cams that make real power.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">spec vs spec should tell you a lot...I have yet to see anyone run the skunk pro cams in an H, only the old skunk cams....
If they are anything like the pro's are to the B series, for the h22, they should slaughter the JUN cams, as far as h22 cams go, the JUNs, though the beefiest popularly available cams, are relatively small when compared to custom cams that make real power.....</TD></TR></TABLE>
2.2EG runs the Pro2's
JDM longblock, Skunk Manifold, Skunk T-Body and some cheap header making 220whp.
HavokB18
19
Aug 29, 2006 02:26 PM
