no power to fuel pump
Old Oct 22, 2006 | 08:44 AM
gsrt nick's Avatar
Default no power to fuel pump
my car died and I have no fuel pressure. I pulled the fuel pump out and tested it and it works I have no power to the fuel pump. I checked the fuel pump fuse and thats ok. I did some searches I couldn't get any direct answers to my problem.
I think its a relay but I dont know where its located and if the main relay and fuel pump relay are the same thing
thanks in advance
Old Oct 22, 2006 | 08:48 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
is power getting to the fuse? the relay is located underneath your steering wheel, it's rectangular, about 2inx1inx1in. mine was brown.
Old Oct 22, 2006 | 09:41 AM
Rikter's Avatar
The main relay and the fuel relay are the same thing. Like Full Circling said the OEM one from, atleast from 90-93, is brown but when you go to replace it Honda gives you a grey one.
-Rik
Old Oct 22, 2006 | 04:44 PM
gsrt nick's Avatar
Default Re: (Rikter)
theres no power to the fuse either
I'm going to just get a relay tomarrow and see what happens
Old Oct 23, 2006 | 03:15 PM
gsrt nick's Avatar
Default Re: (gsrt nick)
anybody else
Old Oct 23, 2006 | 03:40 PM
zeroz's Avatar
maybe you can try to put a light tester right where the harness plugs to your fuel pump and work your way back and maybe you'll spot your problem
Old Oct 23, 2006 | 04:52 PM
CHONCH2's Avatar
you could always run a new wire straight from the ecu to the pump and see i fthats what the deal is
Old Oct 23, 2006 | 05:34 PM
gsrt nick's Avatar
Default Re: (CHONCH2)
I tested the wire at the pump theres no power to it and the fuse is good
I need to know if the main relay controls the fuel pump
Old Oct 23, 2006 | 06:43 PM
benjaminenjamin's Avatar
yes, the main relay powers the fuel pump. put it out and repair the sauder connections....
simply drip new sauder on each existing drip of sauder. be sure not to have any to drops connect, or other electrical problems will arise.
Scarekrow
Oct 11, 2015 08:05 PM
jun10r27
Honda Civic (2001 - 2005)
Dec 15, 2009 08:35 PM
jun10r27
Dec 13, 2009 09:16 AM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
jvans04
Jul 24, 2005 04:49 PM
