Ti vs Oem retainers
Old Oct 22, 2006 | 02:47 AM
civic2slo's Avatar
Default Ti vs Oem retainers
I was wondering how many people are running aftermarket valve springs with stock oem retainers on a B-series? I heard that stock retainers would snap with really hard springs. Anyone can verified this? I really don't care about the benefits on having lighter Ti retainers. I drive my car too much worry about the Ti retainers thinning out. And yes I'm too lazy for me to pull the valvecover every 7,500 to 10,000 miles to inspect them. I can put 5,000 to 7,000 every 3-4 months. So every about year I would have to replace them. I was wondering what valve springs also are you guys running with oem retainer? Portflow, RM, Skunk 2, Toda, Crower, ect. Thanks
Old Oct 22, 2006 | 04:52 AM
NJIN BUILDR's Avatar
Default Re: Ti vs Oem retainers (civic2slo)
Many aftermarket springs won't work with oem retainers.If you worried about ti longevity then have them coated.DLC (diamond like coating) is a good choice.Buffing the ends of the springs will help a lot also.
Old Oct 22, 2006 | 07:56 AM
Forrest Gump 9's Avatar
Default Re: Ti vs Oem retainers (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Buffing the ends of the springs will help a lot also.</TD></TR></TABLE>
You mean by smoothing the end spring out?
Old Oct 23, 2006 | 02:17 AM
civic2slo's Avatar
Just to be specific that I heard that the toda valve springs will worked and have worked with oem retainers with no problems. Is this true?
Modified by civic2slo at 2:57 PM 10/23/2006
Old Oct 23, 2006 | 04:29 AM
IN VTEC's Avatar
Default Re: Ti vs Oem retainers (Turbo9Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut &raquo;</TD></TR><TR><TD CLASS="quote">You mean by smoothing the end spring out?</TD></TR></TABLE>
Yes. It's a common practice done by engine builders to remove sharp edges throughout the motor.
Old Oct 23, 2006 | 06:06 PM
civic2slo's Avatar
Default Re: Ti vs Oem retainers (IN VTEC)
Yes I know that. But has anyone used oem retainers on aftermarket springs.
Old Oct 23, 2006 | 06:24 PM
DonF's Avatar
Stay stock, building anything else requires maintainance. And you obviously do not have the time to check things. Or just go JDM.
Old Oct 23, 2006 | 06:43 PM
allm0torGSR's Avatar
Default Re: Ti vs Oem retainers (DonF)
I'm using ITR outer springs and Portflow inner springs on the intake and exhaust sides, and I use OEM retainers.
Old Oct 23, 2006 | 07:40 PM
IN VTEC's Avatar
Default Re: Ti vs Oem retainers (allm0torGSR)
I've seen stock retainers crack and split with stock GS-R springs. The lash was in spec and rev limiter was only set to 8200rpm. A lot of miles weren't put on the motor either. It was driven only to fun and race events a few times a month, and it was really only driven hard when drag racing at the track.
Old Oct 23, 2006 | 09:40 PM
Well my retainers are fine after 18K miles with a 8500 rpm rev limiter. So what are you saying?
Old Oct 24, 2006 | 05:09 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Stay stock, building anything else requires maintainance. And you obviously do not have the time to check things. Or just go JDM. </TD></TR></TABLE>
Best advice ever^
If your not willing to do the little extra maintence required with aftermarket internals....then don't waste your money.
Old Oct 24, 2006 | 05:48 AM
civic2slo's Avatar
I am already jdm b16 lol...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">
Best advice ever^
If your not willing to do the little extra maintence required with aftermarket internals....then don't waste your money.</TD></TR></TABLE>
The little extra maintenece I don't mind...It's the worrying about thinning out and changing of retainers on a yearly basis. That would get expensive.
Old Oct 24, 2006 | 06:47 AM
Seriously, if you're really worry about Ti retainers, why don't you just use the stock ITR valve trains.
Old Oct 24, 2006 | 04:47 PM
civic2slo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut &raquo;</TD></TR><TR><TD CLASS="quote">Seriously, if you're really worry about Ti retainers, why don't you just use the stock ITR valve trains.</TD></TR></TABLE>
Currently I'm running stock b16a valve train with type r cams. Before anyone start in on I should upgrade the valve springs. I have been running this setup for nearly 4 years with no problems and through numerous mis shifts at the track. I do have type r valve springs but have not installed them. I asked about aftermarket valve springs with oem retainers because I was thinking about installing my toda valvesprings but worry about ti retainer issues. So I was thinking about using the oem retainers. I ws planing on changing my headgasket to a 2 layer and maybe a gsr head to bring my compression ratio to about 10.9 to 1 and use blox b cams just for alittle more hp.
Old Oct 25, 2006 | 11:18 PM
oldskool teggy's Avatar
i have CTR cams with portflow inners, ITR yelow outters on both sides, and i use OEM retainers.. i've had these same valvesprings since 1999 in my car. I've had no problems. I did have problems with portflow ti retainers, but now that i'm using oem. alls been good so far.
I'm plannning to upgrade cams to BC4, and right now i'm prolly going to stick with the same valvetrain. No one can gurantee any retainer will last. oem or not. honestly, i think changing Ti retainers once a year is prolly the safest bet you can go with. just do it when you change your timing belt. which should be around once a year if you race alot anyways.
Old Oct 26, 2006 | 06:37 AM
IN VTEC's Avatar
I'm saying that nothing is a certainty. That's all that I'm saying.
Old Nov 4, 2006 | 01:20 PM
Junkyard2000's Avatar
ive been running oem retainers with skunk2 springs with no problem. As long as you dont rev past 9K youre fine.
Old Nov 4, 2006 | 02:29 PM
Haza45's Avatar
Get them coated and do regular valve adjusments.
Old Nov 4, 2006 | 04:39 PM
mar778c's Avatar
Community Builder
Community Influencer
Ti is not worth the cost if you are not going to regularly inspect them.
Old Nov 5, 2006 | 06:40 AM
A1's Avatar
A1
Default Re: Ti vs Oem retainers (mar778c)
most of my built are running oem retainers w/blox spring and supertech springs. I haven't have broken retainers yet.i used them w/ blox b/c and hsl cams.no problems reving to 9,000 rpm.
Old Nov 5, 2006 | 07:56 AM
onefstek's Avatar
I have used my Ti retainers for about 5yrs. now. I pulled the head a couple of times due to bent valves and a piston melting. But you don't have to check them every 5-7k miles.
Stock will work with aftermarket springs but why use stock, when a good ti. retainer will not cost verry much and the reliabillity is good.
Old Nov 5, 2006 | 08:28 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (onefstek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote">I have used my Ti retainers for about 5yrs. now. I pulled the head a couple of times due to bent valves and a piston melting. But you don't have to check them every 5-7k miles.
Stock will work with aftermarket springs but why use stock, when a good ti. retainer will not cost verry much and the reliabillity is good. </TD></TR></TABLE>
Well because appearantly the Ti retainers tend to wear out in a very short time. Thats great that yours lasted so long but many people on this board seem to have less luck....
Old Nov 5, 2006 | 09:48 PM
Default Re: (cb7-R)
bump
OEM is reliable, just dont use crazy cams and rpm that strain the retainer and spring
BTW, even if you want OEM, get a new or newer set.
Spawne32
Mar 31, 2013 07:31 AM
spoolinvtec54
Mar 17, 2011 12:46 PM
WarpFactorVIII
Aug 20, 2007 06:08 PM
ITRnorway
Mar 6, 2006 07:21 AM
