Dies whenever I am low on gas
Old Oct 22, 2006 | 01:39 AM
GsrTurboCRX88's Avatar
Default Dies whenever I am low on gas
whenever I am low on gas, like 1/4 tank, my car will die and will not start. then i get a code 16 which is the fuel injector code. I don't think it is because i ran out of gas because i still have 1/4 tank, i think there is something wrong with the injectors. but why wouldnt this happen when i have a full tank? I am stumped
Old Oct 22, 2006 | 01:53 AM
ef92b's Avatar
Default Re: Dies whenever I am low on gas (GsrTurboCRX88)
did you replace your fuel pump?
you may read this:
http://www.theoldone.com/articles/fuelpump/
Old Oct 22, 2006 | 05:36 AM
jdmcars.com's Avatar
Also, it may be the gauge reading wrong. Maybe you are lower on fuel than what you think.
Next time you are getting close to the 1/4 tank where it start to die on you, fill up and compair how many gallons you are putting in to how large your tank is -if you put close to the gallons that your tank holds -your were empty and your gauge is just wrong.
Though I more agree (with above reply) it is more than likely a pump -this is simple test to try to find out if it coulde be just the gauge.
Old Oct 22, 2006 | 10:22 AM
Default Re: Dies whenever I am low on gas (jdmcars.com)
thats what I was thinking too but why would i be throwing a fuel injector code?
Old Oct 22, 2006 | 10:29 AM
crawfo661's Avatar
dunno about the injector code, but my guess whould be a bad fuel level gauge good luck
drwoody
May 28, 2010 05:52 PM
traxxasx
Mar 16, 2010 10:21 AM
folta2169
Jul 31, 2007 12:53 PM
db1love
Jul 29, 2006 07:47 PM
eL
37
Oct 20, 2005 03:27 PM
