HELP:how to remore this 3 pcs. wing
Old Oct 21, 2006 | 09:28 PM
anngsr1's Avatar
Default HELP:how to remore this 3 pcs. wing
how to remore this 3 pcs. wing ? 2 corner side which is glued with the body.
Old Oct 21, 2006 | 10:30 PM
gsr dood's Avatar
Default Re: HELP:how to remore this 3 pcs. wing (anngsr1)
rip it off. if u dont wanna do get the body work and paint done, then just leave it. theres nothing u can do....unless u get a heat gun and slowly melt it away....just dont put the gun tooo close or youll burn the clear.
Old Oct 22, 2006 | 08:35 AM
Padawan's Avatar
Darth ModerVader
Are you certain it's glued? It's more likely that the pieces are held on with some sort of automotive adhesive tape, which you should be able to remove without damaging the paint if you work carefully. Try using fishing line or dental floss to work between the car and wing and help release the adhesive. As another member mentioned, a bit of heat can also help, as long as you don't get carried away with it.
Old Oct 22, 2006 | 08:43 AM
JThrasher79's Avatar
Default Re: HELP:how to remore this 3 pcs. wing (Padawan)
dont just start pulling on it. there are two nuts under it holding it on. take off the interior panels and take the nuts off then pull. you will have new holes in your car like mine but i think the holes look better than that stupid wing..
Old Oct 22, 2006 | 09:42 AM
Rikter's Avatar
Looks great! leave it on
Old Oct 22, 2006 | 10:17 AM
Mad Money's Avatar
Default Re: (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">Looks great! leave it on </TD></TR></TABLE>\\\
I agree...looks good with the front end.
Old Oct 22, 2006 | 10:26 AM
DeltaCharlie2's Avatar
Default Re: HELP:how to remore this 3 pcs. wing (JThrasher79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JThrasher79 &raquo;</TD></TR><TR><TD CLASS="quote">dont just start pulling on it. there are two nuts under it holding it on. take off the interior panels and take the nuts off then pull. you will have new holes in your car like mine but i think the holes look better than that stupid wing..</TD></TR></TABLE>
Do not just try and yank it out. Remove your interior panels and see if it's bolted down. You may be able to simply unscrew a couple bolts and have the wing come right off.
Old Oct 22, 2006 | 10:40 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
it actually looks ok. I wold leave it until I decide to paint my car or something like that
Old Oct 22, 2006 | 09:21 PM
anngsr1's Avatar
Default Re: HELP:how to remore this 3 pcs. wing (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">it actually looks ok. I wold leave it until I decide to paint my car or something like that</TD></TR></TABLE>
thanks for all replies, i think i would leave it until I decide to paint my car .
ITR32
Paint and Body
Mar 16, 2008 04:03 PM
GetAwayDriver
Oct 14, 2004 02:46 PM
Siguy00
Mar 30, 2004 06:46 AM
XSSIVE
Nov 29, 2003 12:25 PM
jeebusm3
Jan 22, 2003 02:03 PM
