Having trouble! *cant slip car into any gear* need help ASAP !
Old May 5, 2002 | 04:10 AM
hybrider's Avatar
Default Having trouble! *cant slip car into any gear* need help ASAP !
as i'am writing you this, i just got my car towed, and trying to figure out what the **** is wrong!
i was in 5th gear going 60 on the high way, busted a neutral, as i finish taking the off ramp, i cant get into ANY gear !!!
i pull over, force first nuthing...turn the car off, clutch in and out to see, and i can get into all gears, so i leave it in 1st and start the car.......what happens? the car shakes and turns off ! leave it in neutral start the car, wont go into any gear agian!
what could be wrong? all fluids are properly met (trans,etc) could it be my clutch? tranny?
tia
Old May 5, 2002 | 09:41 AM
JeffS's Avatar
Default Re: Having trouble! *cant slip car into any gear* need help ASAP ! (hybrider93)
What does the clutch pedal feel like? I'm wondering if something happened to cause the hydraulics to loose pressure... a hole in the line, or a loose bleeder screw. I guess you'd see the fluid all over the place if this happened though.
Old May 5, 2002 | 01:21 PM
CivicEx95's Avatar
Default Re: Having trouble! *cant slip car into any gear* need help ASAP ! (JeffS)
Same sort of thing happened in my car. One on the torsion springs on the clutch fell out and jammed things up. You'd try to push in the clutch, and it wouldn't disengage because that spring was there. I could turn off the car, put it into gear, start it, and drive that way. I had to up and downshift without the clutch too and drove it home. Let us know what happens.
Old May 5, 2002 | 02:17 PM
hybrider's Avatar
another thing is, when im in neutral with the car started, and try to force it in any gear the idle falls quite a bit
Old May 5, 2002 | 04:08 PM
hybrider's Avatar
Old May 5, 2002 | 09:58 PM
JeffS's Avatar
It's pretty obviously a clutch problem. I'm not sure that anyone can help you past that. I'd start with the stuff you can check out... like the hydraulics. If things look fine, then I think you're looking at a clutch replacement.
Old May 5, 2002 | 10:43 PM
Slain's Avatar
your master cylinder might have taken a dump on you
Old May 6, 2002 | 07:00 AM
Mista Bone's Avatar
D Tranny Guru
spit a clutch spring, seen it a 100 times.
typical 60k mile GSR problem
Old May 6, 2002 | 12:37 PM
CivicEx95's Avatar
Default Re: Having trouble! *cant slip car into any gear* need help ASAP ! (Mista Bone)
Agreed. Drop the tranny, take of the pressure plate and you'll see your problem. Let us know how it goes.
Old May 6, 2002 | 04:54 PM
hybrider's Avatar
Default Re: Having trouble! *cant slip car into any gear* need help ASAP ! (CivicEx95)
well i took it to a local shop, and guess what? they said the car ran perfectly, and got into every gear with ease !
WTF ! since a friend ownz the place, i told him ill come over to help em drop the tranny and take a look
but damn, thats just weird
tallguy21
17
Feb 27, 2011 05:49 PM
chocolatesk8er10
Jul 25, 2007 11:24 AM
BlackOutIntegra
May 6, 2004 10:47 AM
hybrider
May 6, 2002 07:02 AM
Mr. Softee
Nov 27, 2001 11:36 PM
