Fuel tank drain bolt
Sorry about the excessively large pic, but it is theo nly way you can really see it.... It is #44 in that diagram. It is right below the tank, near the right of the tank:
You will need to drop the botom pan from the tank, to access the drain bolt....
I hope that helps.
I hope that helps.
thanks for the quick reply.
Does anyone know if I have to remove those 2 straps to get the bottom access panel off to get to the bolt? Or are those only on the tank itself. I would go look myself but the car is not here right now. Thanks again.
boostedK20a2
Jun 20, 2006 08:36 AM
Beave0101
Jan 2, 2004 11:40 PM
