Exhaust wrap
Old Oct 21, 2006 | 05:05 PM
8_6 luder's Avatar
Default Exhaust wrap
So whats the deal with exhaust wraping? Is it good or bad? I've researched the topic to find that some believe it to work as a plus due to the lower bay tempature ,while also gaining power by the increased heat confined to the header , downpipe etc. I have also heard that the same addition in heat within the exhaust system potentially damages heads by extreme warpage. Whats the deal? I wanna wrap my pipes but im afraid of negitive results.
Old Oct 21, 2006 | 05:12 PM
avallach's Avatar
Default Re: Exhaust wrap (8_6 luder)
Well, I got my header wrapped recently and did notice that my hood DOES NOT get as hot as it used to. After coming home, I think I could actually fry an egg on my hood without the header wrap. Good or bad? Can't answer that yet.
Old Oct 21, 2006 | 05:26 PM
cifer6425's Avatar
the only negative i have heard goes something like this.
the exhaust wrap will hold moister, this could/will result in rusting. some do not recommend it on daily drivers.
i have no experience, i am just repeating what i have heard/read.
Old Oct 21, 2006 | 06:20 PM
8_6 luder's Avatar
How could that be possible? Wouldnt the heat instantly evaporate any moisture? I would think so.
Old Oct 21, 2006 | 07:09 PM
Hawkze_2.3's Avatar
Default Re: (8_6 luder)
I have header wrap-shaped rust all over my DC header. It will hold in moisture unless you run your car 24 hrs a day....which I didn't.
Old Oct 21, 2006 | 09:05 PM
Buffalo's Avatar
Default Re: Exhaust wrap (cifer6425)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cifer6425 &raquo;</TD></TR><TR><TD CLASS="quote">the only negative i have heard goes something like this.
i have no experience, i am just repeating what i have heard/read.</TD></TR></TABLE>
i believe thats not a problem if you have ss header
Old Oct 21, 2006 | 11:11 PM
Silver Surfer's Avatar
the purpose is not necessarily to lower heat in the engine bay although it may help a little
heat wrap is designed to keep the heat in the header.....hotter gas will increase the exhaust velocity and flow aiding the scavaging effect that a good header will produce
conversely they make heat tape....it is designed to keep heat out.....i guess you could wrap your intake with it or other things you want to keep cooler than the rest of the engine bay
Old Oct 21, 2006 | 11:39 PM
MadCityLude
Guest
Posts: n/a
Default Re: Exhaust wrap (Buffalo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buffalo &raquo;</TD></TR><TR><TD CLASS="quote">i believe thats not a problem if you have ss header</TD></TR></TABLE>
Contrary my friend.
SS WILL RUST.
It just won't rust as easily-quickly
561teggy
Apr 21, 2013 04:31 AM
JDM-h22a
Oct 13, 2009 06:57 PM
em1_mark
Dec 28, 2005 10:09 PM
Stein
Aug 31, 2005 09:33 AM
lsteggy
Oct 16, 2002 01:41 PM
