rack end lock washer
I am currently attempting to replace my rack ends (inner tie rod end). I am stuck on the lock washer/removing the acctual rack end.
I have no idea how to remove it. There is no space to turn a wrench and the lock washer tabs appear to be impossible to bend up.
I need help!!
Do i need to remove more components of the under carrage to make more room or what?
I need help!!
cut the rack ends off right before hex part, then you can get a screwdriver on the locks, bend them away, and put a socket on the hex, remove it, clean threads of rack add locktite, put the new rack ends on. the new ones should have a larger hex area where a wrench will fit.
Stea
20
Jul 10, 2021 07:14 PM
zanedub
Dec 10, 2015 06:46 PM
Jaydeep
Honda Civic (2001 - 2005)
Aug 29, 2012 09:45 PM
