Car won't start!!! Help please
The other day the car wouldn't start. It would turn over occasionally but just wouldn't fire up. I figured the starter was going or was gone. While inspecting the bay I noticed the alternator belt needed replacing so I went in and replaced both but the car is doing the exact same thing.
Since I moved to Virginia I have had to replace the fuel filter twice but both times the car acted as if the battery was dying. Once I replaced the fuel filter it started right up. I have a volt gauge in the car and it says with the key in accessories position it is approximately 10 volts and I know 12-14 is normal but once I turn the key to on and it drops to around 2-5 volts. I am at a loss as to what to do here. I can replace the fuel filter again but would like to find the root cause of the problem. Thanks
Modified by angelscrx at 1:45 PM 10/28/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR »</TD></TR><TR><TD CLASS="quote">If everything check out fine... Then you have as lose ground wire somewhere....
**** on a loose ground, i had one and i was looking for what was going on for like an hour then i went over all my grounds and found that i had a loose ground.
</TD></TR></TABLE>**** on a loose ground, i had one and i was looking for what was going on for like an hour then i went over all my grounds and found that i had a loose ground.
iblingidawg
May 5, 2005 02:48 PM
