Crower 403s on a Stock b20z
Old Oct 21, 2006 | 10:13 AM
gutted-dx's Avatar
Default Crower 403s on a Stock b20z
Should i upgrade the springs, and retainers, or would i be good on stock.
Old Oct 21, 2006 | 05:52 PM
JCushing's Avatar
Default Re: Crower 403s on a Stock b20z (gutted-dx)
you can keep the old ones if they are in good shape and you keep the stock rev limmit.
if they are old or your unsure of the quality or you want to raise the redline then you NEED better springs. retainers are optional
Old Oct 21, 2006 | 11:30 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: Crower 403s on a Stock b20z (JCushing)
personally the safe bet is to upgrade it all.
Old Oct 23, 2006 | 01:26 PM
gutted-dx's Avatar
I'll prolly get the cams then upgrade the springs and **** later.
Old Oct 23, 2006 | 04:26 PM
Darkane's Avatar
Default Re: (gutted-dx)
If you are getting springs, get the 404's instead. Will see more gains.
Old Oct 24, 2006 | 08:41 PM
thawley's Avatar
Take a look at the Brian Crower (http://briancrower.com/) stage II cams. We tested them (along with springs and retainers) last month and were VERY impressed. The Hondata S300 tune file is going to be posted on Hondata's web site for a free download. They are bitchen cams. Zero downside. Every B20 on the planet should have a pair.
Watch Turbo Magazine for more details. We tested the BC stage II, stage III and a Blox Type-R style manifold. Good stuff. All tuning files will be free downloads from Hondata.
Thawley
Old Oct 25, 2006 | 06:36 AM
blundar's Avatar
One of the guys I work with at Zerolift (TJ) has had 403s in his LS motor for a long time now - year or two? Stock valvetrain, stock(ish) redline -7500, no problems yet. They have pretty impressive gains versus stock LS cams, but I'd echo the suggestion of going with a larger cam if you're staying NA and buying valvetrain.
Old Oct 25, 2006 | 06:42 AM
JCushing's Avatar
Default Re: (thawley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote"> Every B20 on the planet should have a pair.
i dunno about that.. maybe if they make a much larger cam ill take a look at em
Old Oct 25, 2006 | 12:24 PM
gutted-dx's Avatar
-Dave, what other mods does he have, and has it been on the dyno yet.
Old Oct 25, 2006 | 02:43 PM
blundar's Avatar
P30 pistons, crappy header, crappy intake, tuning
been on the dyno - don't remember how it did.
165ish I wanna say on the dyno dynamics... With the stock head and crap header/exhaust, there wasn't a point revving it higher than 7500. TJ has the dyno chart I think.
Old Dec 11, 2006 | 06:48 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (blundar)
I'm bumping this from the past, but looking at the specs, aren't the Brian Crower stage 2s almost exactly the same as the Crower 403s?
Old Dec 11, 2006 | 06:54 PM
s10cky's Avatar
im sorry for the dumb question but why is there a brian crower and crower, are they diff?
Old Dec 11, 2006 | 06:55 PM
b19coupe's Avatar
Default Re: (s10cky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">im sorry for the dumb question but why is there a brian crower and crower, are they diff?</TD></TR></TABLE>
Brian Crower left Crower and started his own company.
Old Dec 12, 2006 | 05:17 AM
Suspetise...
Default Re: (b19coupe)
b19, do you know anything about the difference (if any) between the two cams?
Old Dec 12, 2006 | 07:08 AM
b19coupe's Avatar
Default Re: (Stinkycheezmonky)
Brian Crower cams BC0022:
Adv. Dur. ------Dur @ .050----- Lift (in)------------Lift (mm)
300°/300° -----222°/220°------ .423"/.413"-------10.74/10.49
Crower cams-62403-2
Advertised duration--------Dur. @ 0.050"------------ Gross lift
264 / 264-------------------221 / 220-------------------422 / 411
The cams are quite similar in specifications for some reason
Old Dec 12, 2006 | 08:55 AM
s10cky's Avatar
I recon I should support Brian Crower then huh?
Old Dec 14, 2006 | 09:31 AM
Glen Tennis's Avatar
I'm about to put some 404's in my B20Z !!!
Old Jan 10, 2007 | 10:22 AM
redDAinteg's Avatar
CROWER 403 LS and B20 CAMS and GEARS FOR SALE
https://honda-tech.com/zerothread?id=1858987
Modified by redDAinteg at 6:30 PM 1/10/2007
Old Jan 10, 2007 | 04:26 PM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">I'm bumping this from the past, but looking at the specs, aren't the Brian Crower stage 2s almost exactly the same as the Crower 403s?</TD></TR></TABLE>
They are pretty close. The BC cams are ground with small diameter wheels that somehow change the ramp angles and get the valve open faster. Brian expained it to me once, but I am a retard, and don't remember exactly how it works.
Both CROWER and BC/Brian Crower are good companies with good products. Brian was the main import dude when he worked at his uncle's company and now he's got his on business.
Old Jan 11, 2007 | 05:07 AM
Rosetta Stoned's Avatar
So would i be correct in saying that out of the 404 and the BC stage 2, the 404s are the bigger cam?
Old Jan 11, 2007 | 05:42 AM
b19coupe's Avatar
Default Re: (Rosetta Stoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosetta Stoned &raquo;</TD></TR><TR><TD CLASS="quote">So would i be correct in saying that out of the 404 and the BC stage 2, the 404s are the bigger cam?</TD></TR></TABLE>
Yes.
Old Jan 11, 2007 | 05:52 AM
Thanks.
Looks like im going with the 404 then.
Old Jan 11, 2007 | 10:31 AM
actually ive been reading on these cams alot and im not sure what im going to get.
Is the difference between the brian crower stage 2 and crower 404 that big?
When would the BC 2 cams become "too small?"
These cams+valvetrain are going on an otherwise stock LS (i/h/e).
Im going to build a shortblock and bump the compression eventually, so im trying to buy the cams that are going to work well in both setups.
How is the idle with the BC 2 cams?
Sorry about all the n00b questions. Thanks alot guys.
Old Jan 11, 2007 | 08:08 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosetta Stoned &raquo;</TD></TR><TR><TD CLASS="quote">How is the idle with the BC 2 cams?
Slightly lumpy, but in a good way
Old Jan 21, 2007 | 04:49 AM
gutted-dx's Avatar
I just picked up a AN-R header for $150, the cams are next on the list.
