Timing on a d16z6???
Old Oct 21, 2006 | 09:16 AM
Red_Si's Avatar
Default Timing on a d16z6???
I have a d16z6 going into my ef. I have everything hooked up and when i started it, it was running like ****, so i noticed the timing was off. I align the cam gear to top where it should be. The crank pulley is about to go on but i don't know if i'm doing this right. When i put the crank pulley back on should the mark on the block line up with the 0btc mark on the crank pulley??? It seems that is the only way to get it on? I thought it was supposed to look like this???
what am i doing wrong, please help asap, i'm trying to get this thing running today!!!
Old Oct 21, 2006 | 10:24 AM
nighttrain33's Avatar
Default Re: Timing on a d16z6??? (Red_Si)
I found the easiest way when I replaced my oil pump was to use the pointer on the the crank sprocket and align it with the pointer on the oil pump housing. Obviously the timing belt would have to be taken off of the cam so that you can adjust cam timing separately from crank timing. Just a thought.
And to answer your question, yes. The single mark on the crank pulley should line up with the mark on the block.
-Shane
Old Oct 21, 2006 | 10:29 AM
NJcoupe's Avatar
Default Re: Timing on a d16z6??? (nighttrain33)
Yes. The Single mark 0 BTC should be set to the pointer, when the car is running, service connector jumped, it should 16 BTC.
Old Oct 21, 2006 | 10:41 AM
Red_Si's Avatar
Default Re: Timing on a d16z6??? (dxcoupe.)
ok i've never done this before. I got the crank pulley 0btc at the notch on the block. How do i do cam timing??? i only have the timing belt on the crank, tensioner, and waterpump right now, not on the cam. thanks for the help in advance guys!!!
Old Oct 21, 2006 | 10:43 AM
There should be an "up" stamp on your cam. Put this in the up position and the head will be at TDC. Then put the timing belt back on while keeping the crank pulley stationary. It is a lot easier with the help of someone else.
-Shane
Old Oct 21, 2006 | 04:24 PM
oxmark4's Avatar
take off both gears and line up the arrows on the crank and the cam gear and slide the gears back on and you should be golden
Old Oct 21, 2006 | 09:07 PM
Default Re: Timing on a d16z6??? (oxmark4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxmark4 &raquo;</TD></TR><TR><TD CLASS="quote">take off both gears and line up the arrows on the crank and the cam gear and slide the gears back on and you should be golden</TD></TR></TABLE>
What gears?
-Shane
Old Oct 22, 2006 | 05:22 PM
oxmark4's Avatar
cam and crank gears
civicboy420
Jun 5, 2014 09:13 PM
dkaficky
16
Nov 15, 2010 10:25 AM
88crxdxfastwhip
Jun 13, 2008 11:56 AM
Aquafina
May 24, 2008 05:27 PM
SL_RICK83
Jun 27, 2006 07:38 PM
