Suspension & Brakes Theory, alignment, spring rates....
GSR rear sway on EG - need subframe brace?
Old Oct 21, 2006 | 04:26 AM
no_money2supe's Avatar
Default GSR rear sway on EG - need subframe brace?
I've tried searching already but can't seem to find an answer for EG's specifically.
It seems people recommend a subframe brace for EK's with a rear sway larger than 13mm, but I've also read that EG frames are a tad bit stronger. So, for my application, will I be needing the said subframe brace on my EG with a GSR rear sway (14mm)? Thanks in advance!
Old Oct 21, 2006 | 11:21 AM
byronl's Avatar
Default Re: GSR rear sway on EG - need subframe brace? (no_money2supe)
i've put one on my 93 coupe and didn't need a brace.
Old Oct 21, 2006 | 01:11 PM
eg9matt's Avatar
ha ha ur fine and you dont need a subframe brake i run a 22mm type r rear sway with a homemade mounting kit and been running this for a year and a half with out problems so you will be fine
Old Oct 21, 2006 | 01:45 PM
Default Re: (eg9matt)
Okay, thanks, that's all I needed to know!
Old Oct 22, 2006 | 07:33 PM
Lord Helmet's Avatar
Default Re: (no_money2supe)
I have a 19mm rear sway on my EJ1 for over 4 yrs and no subframe brace at all. not cracks or issues either.
saveacivic
Northwest (Sales)
Aug 17, 2010 09:22 PM
cranberry
Suspension & Brakes
Jul 14, 2010 10:10 PM
gamby
Nov 10, 2007 08:31 PM
Scotty Dosent Know
Suspension & Brakes
Aug 28, 2005 08:18 AM
